    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
    • L
      leminilab
      @diego-rodriguez said:
      this is the error.
      I use
      windows xp sp3, in Spanish. sketchup sketchup 8 in Spanish and 7 in Spanish
      in the two versions generated BugSplats.
      the image is made with sketchup 8.
      although sketchup 7, BugSplats generates but does not generate error reporting in the console ruby
      [attachment=1:3ncjb9nt]<!-- ia1 -->file without zoom.gif<!-- ia1 -->[/attachment:3ncjb9nt]
      [attachment=0:3ncjb9nt]<!-- ia0 -->mirror 01.jpg<!-- ia0 -->[/attachment:3ncjb9nt]
      Hi !
      A little off topic but how did you do that animated gif ? It's looking good !
      Nicolas
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
        sents=[]
            	ss.each{|e|sents.push(e)}
            	  copy_group=Sketchup.active_model.active_entities.add_group(sents)
              group_miner(copy_group.entities)###v3.1
                new_group=copy_group.copy
              group_miner(new_group.entities)###v3.1
        The last line is #266.
        It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, starting at line #109
            def activate
                ###Sketchup.send_action("showRubyPanel;")
                self.reset()
                ss=Sketchup.active_model.selection
                if ss.empty?
                    Sketchup;;set_status_text("Mirror; NO Selection !")###
            		UI.messagebox("Select Something BEFORE Using the Mirror Tool.")###v2.8
                    Sketchup.send_action("selectSelectionTool;")
                    return nil
        Have you messed up the code with the translation ?
        • OxerO
          Oxer
          @tig said:
          sents=[]
          It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, staring at line #109
          >     def activate
          >         self.reset()
          >         if ss.empty?
          >             return nil
          >         end
          I haven't done changes in the code only i have translated the UI.messagebox and the text of the popups windows, i have probe with the mirror 3.3 original version (english) and don't works too.
          I don't know if there is a conflict with others plugins.
            šŸ˜•
            Can you try it with the 'Ruby Console' open and post all error messages...
            This is a puzzle... šŸ˜•
            • OxerO
              Oxer
              I have found the error!
              There is a conflict with SketchyPhisics 3.1, remember i work on Mac OSX.
              Excuse me, it not was a problem in the plugin there were a conflict.
              Thanks TIG””
                It's no problem for me! Now it's no problem for you!
                ”No hay problema para mí! ”Ahora no es problema para ti!
                • G
                  glro
                  Thanks TIG””
                  i use windows XP SP3, and i noticed also a conflict between Mirror and Sketchyphysics3
                  too bad, we'll have to choose between 2 excellent plugins...
                  • cottyC
                    cotty
                    Thanks TIG””
                    Is there a solution to solve this conflict?
                    my SketchUp gallery
                      Here's v3.4 with some more code tweaks that might stop bugs...
                      http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                      • kenK
                        ken
                        I know this is an operator error. I have noticed if you press the delete key instead of the return, the plugin crashes. Is there a way to capture the delete key so it will not crash Sketchup.
                        Yes, I know I should be more careful.
                        Thank you for your plugin
                        Ken
                          DIEGO-RODRIGUEZ
                          tig thanks for this new update.
                          but unfortunately continues to generate bugplat when ouliner window this open, and make mirror for a group or component.
                          use sketchup 8, windows xp sp3
                            It should roll up the Outliner in Windows ? šŸ˜•
                              davidlouis
                              I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-intoduce the necessary lines in the code to enable it to appear in the context menu....
                              Sorry but i am a creature of habit and the use of the icon interrupts my usual workflow...
                              Thanks in advance.
                              Dave
                                @davidlouis said:
                                I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-introduce the necessary lines in the code to enable it to appear in the context menu....
                                Thanks in advance.
                                Dave
                                Sorry about that...
                                I disabled it temporarily whilst I was doing something else!
                                Here's v3.5 that has it reintroduced...
                                šŸ˜’
                                • B
                                  budz
                                  thanks for sharing a great plugins like this sir,..
                                  • L
                                    LannorMov
                                    Tig: Thanks for that gift so beautiful. I'm using a lot and it works well.
                                      Dominance
                                      thanks for your sharing
                                      • dereiD
                                        derei
                                        @TIG: Could you make some loader for this ? I would like to have a folder with "MI.png, Mirror.rb and toggleWindows.rb" and a Mirror_loader.rb (or similar). Win32API.so I thinks it's best to stay in Plugins folder, as it is used by more plugins.
                                        Thanks a lot.
                                        DESIGNER AND ARTIST DEREI.UK
                                          Thanks a lot.
                                          If you want to move files you need to rewrite the menu/toolbar part of their code to ensure the files are found in the new sub-folder.
                                          A loader is a simply a file in the ../Plugins/ folder called perhaps myloader.rb containing this line of code
                                          load "mysubfolder/myscript.rb"
                                          The line can be repeated for multiple files to be loaded...
                                          Where mysubfolder is a folder in ../Plugins/ containing the script myscript.rb that you want loading...
                                            dedmin
                                            Today I noticed when I mirror a component the mirrored copy gets "Scale definition" active. When click to reset it rotates 180 degree, when choose to scale the original now gets "Scale definition"?
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 2 / 11
