    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 76.5k Views 24 Watching
    • mitcorbM Offline
      mitcorb
      Thanks for your explanation, TIG
      You are an amazing dude.
      Another question. Could this tendency toward deprecation be the reason why older scripts that worked fine last year, suddenly do not work this week, even though the same SUversion is being used?
      • Didier BurD Offline
        Didier Bur
        Yes, especially since SU8 is out. The API "uses" a newer version of Ruby that is less permissive, concerning arguments within brackets, no spaces between function name and arguments, and such boring coding stuff. ๐ŸŽ‰
        DB
        • mitcorbM Offline
          mitcorb
          Didier wrote:
          "...such boring coding stuff"
          I am dragging this way off topic, but one more comment and I will quit.
          I superficially understand that all of those punctuation marks and symbols are a way to organize the input, but why should input be so tedious? Just think about it, don't answer so that this thread can continue.
            JGA
            Thanks very much, it works well!
            Regards,
            JGA
              chenkl
              Thanks TIG
                Life is encapsuled (Life) ๐Ÿ˜†
                Keep the good work ๐Ÿ˜Ž
                  CAD Addict
                  I haven't had time to try it, but I have a question.
                  Isn't it the same as the Sandbox tools can do?
                  What does it do better than the standrads sandbox?
                  http://www.cad-addict.com
                    @cad addict said:
                    I haven't had time to try it...
                    Isn't it the same as [what] the Sandbox [does]...?
                    What does it do... better...?...
                    No, it's quite different!
                    The 'opposite' tool in fact...
                    The Sandbox tool takes contours supplied to it, that are already set at the correct heights, and makes a mesh surface from them.
                    The ContourMaker tool takes a mesh surface and it makes [grouped] contours from it.
                    Your mesh might not have been made from contour data at all, but contours can be very useful when visualizing a complex land-form - this tool lets you add them.
                    ๐Ÿค“
                    • irwanwrI Offline
                      irwanwr
                      i'd like to try this plugin.
                      i'd like to see if i can draw (or model) a pond near a tent or a house perhaps.
                      i just love to draw ๐Ÿ˜„
                      thank you ๐Ÿ‘
                        thank you ๐Ÿ‘
                        Get it from the link in the first post in this thread...
                        • irwanwrI Offline
                          irwanwr
                          umm... i think i still cannot understand how it works and to use it though
                          need to learn more about instruction, mesh definition, etc. ๐Ÿ˜ž
                            The contours are cut through a grouped mesh [e.g. a terrain surface that is a group]...
                            • marvins_dadM Offline
                              marvins_dad
                              Man that is sweet Tig!
                              Thanks for another great ruby!
                              My Gallery
                                mrdcon
                                I've downloaded the plugin and created contours for a meshed terrain model that was generated from Goodle maps. Now that I have contours on the meshed terrain model, other than seeing contours, what else can I do with them. I've tried to manipulate the contours (ie, push /pull, etc.) but they are not editable. Am I missing something?
                                  Use your imagination ?
                                  Perhaps all some people need is some contours drawn over their terrain to help visualize their design...
                                  But if you want a simplified surface mesh made from the contours edit their group and use the Sandbox tool to make a 'surface from contours'.
                                  The coarser you space the contours the more simplified is the new mesh...
                                  You decide what to do with the tool - I only made it ๐Ÿ˜’
                                    arystoteles
                                    thank you for the plugin!
                                    However I was wondering if you could suggest a tip to rebuild the curves and make them ultra smooth?
                                    • massimoM Offline
                                      massimo Moderator
                                      Well the smoothness of the curves is related to the smoothness of the mesh.
                                      Here I've used "Artisan" plugin to smooth the terrain.
                                        arystoteles
                                        Oh I see thank you Massimo!
                                        But regardless of the terrain mesh is there a function in Sketchup to rebuild a curve wit fewer points and therefore smooth it out?
                                          If you don't want to mess with the mesh you could use a edge 'smoothing' tool...
                                          I think Thomthom has something in his Edge Tools set - you'll [probably] have to use weld.rb on each connected set of contour-lines to make 'curves' from them firs, since they are made as raw individual edges...
                                          • massimoM Offline
                                            massimo Moderator
                                            You could also use Fredo's bezier spline plugin. Select the curve-->right click-->convert to... ("catmull spline" for example), but as TIG said the curves will intersect with the mesh.
                                            • 2 / 4
