    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 75.9k Views 24 Watching
    • TIGT Online
      It does exactly what you tell it to do...
      If you move the mesh up in the Z by 1mm the result will change... 😒
      The contours are 'true' - the mesh might not be exactly as you hope BUT the 'contours' represent what is there...
      • simon le bonS Offline
        simon le bon
        Ah OK!
        I think I began to understand how Contour maker works.
        The Contours always start their vertical spacing from Z=0 UP & DOWN.
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thContourMaker002.jpg
        😕 simon
        • TIGT Online
          Here's v1.6 - http://forums.sketchucation.com/viewtopic.php?p=273795#p273795
          Minor corrections to syntax [arguments all inside () ] that has no affect on results but covers possible future deprecation...
          • mitcorbM Offline
            mitcorb
            Hi,TIG:
            Could you explain what you mean by possible future deprecation?
            It suggests to me that other tools may not tolerate the use of this one?
            • TIGT Online
              A method's 'deprecation' is when a method or a part of a method is no longer 'used' or 'works'.
              For example in many API examples in the guides it will say for things like:
              entities.add_cline point1, point2
              this works fine in past and current versions...
              BUT the 'standard' way recommended in Ruby and guaranteed to stop faults is to use 'parenthesizes' to enclose all arguments, like this
              entities.add_cline(point1, point2)
              [Note NO space between the method and opening ( and the arguments are separated by ',']
              This also gets over the occasional glitch that occurred in existing code with the new PC version of Ruby shipped with v8, for example in v7 this [probably] worked
              my_command (x+y/2), z
              in v8 it will fail because the first set of stuff inside the '()' is taken as all the arguments there are and the following ', z' throws an error, but changed to
              my_command((x+y/2), z)
              it then works for both versions and is also 'future-proof' as all of the arguments are now encapsulated inside the ()...
              • mitcorbM Offline
                mitcorb
                Thanks for your explanation, TIG
                You are an amazing dude.
                Another question. Could this tendency toward deprecation be the reason why older scripts that worked fine last year, suddenly do not work this week, even though the same SUversion is being used?
                • Didier BurD Offline
                  Didier Bur
                  Yes, especially since SU8 is out. The API "uses" a newer version of Ruby that is less permissive, concerning arguments within brackets, no spaces between function name and arguments, and such boring coding stuff. 🎉
                  DB
                  • mitcorbM Offline
                    mitcorb
                    Didier wrote:
                    "...such boring coding stuff"
                    I am dragging this way off topic, but one more comment and I will quit.
                    I superficially understand that all of those punctuation marks and symbols are a way to organize the input, but why should input be so tedious? Just think about it, don't answer so that this thread can continue.
                      JGA
                      Thanks very much, it works well!
                      Regards,
                      JGA
                        chenkl
                        Thanks TIG
                          Life is encapsuled (Life) 😆
                          Keep the good work 😎
                            CAD Addict
                            I haven't had time to try it, but I have a question.
                            Isn't it the same as the Sandbox tools can do?
                            What does it do better than the standrads sandbox?
                            http://www.cad-addict.com
                            • TIGT Online
                              @cad addict said:
                              I haven't had time to try it...
                              Isn't it the same as [what] the Sandbox [does]...?
                              What does it do... better...?...
                              No, it's quite different!
                              The 'opposite' tool in fact...
                              The Sandbox tool takes contours supplied to it, that are already set at the correct heights, and makes a mesh surface from them.
                              The ContourMaker tool takes a mesh surface and it makes [grouped] contours from it.
                              Your mesh might not have been made from contour data at all, but contours can be very useful when visualizing a complex land-form - this tool lets you add them.
                              • irwanwrI Offline
                                irwanwr
                                i'd like to try this plugin.
                                i'd like to see if i can draw (or model) a pond near a tent or a house perhaps.
                                i just love to draw 😄
                                thank you 👍
                                • TIGT Online
                                  thank you 👍
                                  Get it from the link in the first post in this thread...
                                  • irwanwrI Offline
                                    irwanwr
                                    umm... i think i still cannot understand how it works and to use it though
                                    need to learn more about instruction, mesh definition, etc. 😞
                                    • TIGT Online
                                      The contours are cut through a grouped mesh [e.g. a terrain surface that is a group]...
                                      • marvins_dadM Offline
                                        marvins_dad
                                        Man that is sweet Tig!
                                        Thanks for another great ruby!
                                        My Gallery
                                          mrdcon
                                          I've downloaded the plugin and created contours for a meshed terrain model that was generated from Goodle maps. Now that I have contours on the meshed terrain model, other than seeing contours, what else can I do with them. I've tried to manipulate the contours (ie, push /pull, etc.) but they are not editable. Am I missing something?
                                          • TIGT Online
                                            Use your imagination ?
                                            Perhaps all some people need is some contours drawn over their terrain to help visualize their design...
                                            But if you want a simplified surface mesh made from the contours edit their group and use the Sandbox tool to make a 'surface from contours'.
                                            The coarser you space the contours the more simplified is the new mesh...
                                            You decide what to do with the tool - I only made it 😒
                                            • 2 / 4
