    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 78.9k Views 24 Watching
    • irwanwrI Offline
      irwanwr
      umm... i think i still cannot understand how it works and to use it though
      need to learn more about instruction, mesh definition, etc. 😞
        The contours are cut through a grouped mesh [e.g. a terrain surface that is a group]...
        • marvins_dadM Offline
          marvins_dad
          Man that is sweet Tig!
          Thanks for another great ruby!
          My Gallery
            mrdcon
            I've downloaded the plugin and created contours for a meshed terrain model that was generated from Goodle maps. Now that I have contours on the meshed terrain model, other than seeing contours, what else can I do with them. I've tried to manipulate the contours (ie, push /pull, etc.) but they are not editable. Am I missing something?
              Use your imagination ?
              Perhaps all some people need is some contours drawn over their terrain to help visualize their design...
              But if you want a simplified surface mesh made from the contours edit their group and use the Sandbox tool to make a 'surface from contours'.
              The coarser you space the contours the more simplified is the new mesh...
              You decide what to do with the tool - I only made it πŸ˜’
                arystoteles
                thank you for the plugin!
                However I was wondering if you could suggest a tip to rebuild the curves and make them ultra smooth?
                • massimoM Offline
                  massimo Moderator
                  Well the smoothness of the curves is related to the smoothness of the mesh.
                  Here I've used "Artisan" plugin to smooth the terrain.
                    arystoteles
                    Oh I see thank you Massimo!
                    But regardless of the terrain mesh is there a function in Sketchup to rebuild a curve wit fewer points and therefore smooth it out?
                      If you don't want to mess with the mesh you could use a edge 'smoothing' tool...
                      I think Thomthom has something in his Edge Tools set - you'll [probably] have to use weld.rb on each connected set of contour-lines to make 'curves' from them firs, since they are made as raw individual edges...
                      • massimoM Offline
                        massimo Moderator
                        You could also use Fredo's bezier spline plugin. Select the curve-->right click-->convert to... ("catmull spline" for example), but as TIG said the curves will intersect with the mesh.
                          arystoteles
                          Thank you guys for very useful and quick reply! (this forum is amazing)
                          I just had a look at edgetools by Thomthom as TIG suggested but as I have understood simplyfy curves would rather simplyfy the curves into more rugged even further. (but I might definitely use it for some other stuff πŸ˜„
                          Massimo you are my hero! BezierSpline plugin is just what I was looking for. Curves will intersect with terrain a little bit but I hope to fix it the final image by exporting terrain to Layout first and than overlaying curves on top with different file that has terrain hidden...
                          • goatboyG Offline
                            goatboy
                            TIG:
                            Upgraded to 2014. Contourmaker.rb is in my migrated plugins...I don't see it.
                            Arrgghh! This was my one contribution as an architect to a heavy civil team!
                            Help!
                            • BoxB Offline
                              Do not migrate plugins, install fresh updated versions.
                                Goatboy, the version you have must be old because the last version of it was updated at the end of April of 2013 and it works fine in SU2014. Or you didn't install it correctly or in the right place. As Box said, don't migrate plugins. Install fresh copies. Get the SCF Plugin Store and install it automatically.
                                • goatboyG Offline
                                  goatboy
                                  Yes, that did it. Also in the 2014 thread, Jim corrects some really incorrect instructions from Trimble on how to migrate plug-ins:
                                  @jim said:
                                  On Vista, Win 7, 8:
                                  C;\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                  On Win XP:
                                  C;\Documents and Settings\<username>\Application Data\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                  On Windows, we also load plugins from a user-independent support directory.
                                  On Win Vista, 7, 8:
                                  C;\ProgramData\SketchUp\SketchUp 2014\SketchUp\Plugins
                                  On Win XP:
                                  C;\Documents and Settings\All Users\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
                                  This path is only loaded to the $LOAD_PATH array if the folder exists when on the user's machine when SU starts.
                                  but your way: the SCF Plugin Store is way better. Thanks!
                                    Where are the incorrect instructions?
                                    • goatboyG Offline
                                      goatboy
                                      Like in the 2014 help directions...
                                        So it does.. I sent a request for a correction.
                                          Get and install the latest version of ContourMaker from the PluginStore RBZ [Preferences > Extensions > Install...].
                                          http://sketchucation.com/pluginstore?pln=ContourMaker
                                          It is compatible with v2014.
                                          OR do it automtically from within SketchUp itself using the SketchUcation 'Plugin Store' AutoInstall capabilities...
                                          Either way the correct Plugins folder is found for you...
                                          • goatboyG Offline
                                            goatboy
                                            TIG: I hope you have already been gold-plated. When I read the methods others use to make contours, I am SO GLAD I found contour maker.
                                            • 2 / 4
