    Sketchup crashes when starting
    38 Posts 15 Posters 43.0k Views 15 Watching
    • G Offline
      GhostFist
      HI, new here. I'm also having this immediate crash/bug splat on starting up a fresh install of Sketchup make. Sketchup 8 was running fine un til I installed this along side it now neither work. uninstalled both, reinstalled 2013 works once then I get the crash on start up. Graphics drivers are up to date. Running on Windows 8. really disappointing.
        Is that with or without plugins installed?
        • G Offline
          GhostFist
          this is a stock download as it comes off the trimble site. never had this problem on earlier versions of sketchup
            Anton_S
            Download CCleaner and run both cleaner and registry section. I had the same error a long time ago, tried CCleaner, and got the magic. 😎
            • G Offline
              GhostFist
              CCleaner did not work
                I find that these registry cleaners can mess up more than they fix. I'd really not recommend them.
                  Uninstall 2013.
                  Reinstall 2013, this time 'run as admin'.
                  Report back...
                  • G Offline
                    GhostFist
                    Been there done that, same issue.
                      Did you install it 'as admin'?
                      Then set it to always 'run as admin'?
                      πŸ˜•
                      • G Offline
                        GhostFist
                        yup, really scratching my head on this.
                        • G Offline
                          GhostFist
                          Problem resolved when rolling back the graphics driver
                            Out of interest, what is/was your GC / drivers set ?
                            It might help others to be forewarned...
                            • G Offline
                              GhostFist
                              Sketchup was running into problems using the Microsoft surface PRO after updating the graphics drivers from INTEL's site. Microsoft has written a custom driver for the surface pro's chipset and so a conflict was created. Removing Intel's generic driver and rolling back to Microsoft's resolved all issues.
                              • sketch3d.deS Offline
                                sketch3d.de
                                @coulteri said:
                                I will try to upgrade the graphic card drivers.
                                you may want try also to disable the SU hardware acceleration (= OpenGL) from outside SU by using our concerning standalone support tool (Win only).
                                free for private & commercial usage (no adware/spyware/installation)
                                [update]
                                tool updated for being compatible with SU v2013/2014.
                                [/update]
                                hth,
                                Norbert
                                  MILENIUMFALCON
                                  hey tig i found the culprit rb folder crashing my sketchup and it was your axo+iso plugin. Any ideas how to make the plugin work? reply ASAP..
                                  Thanks in advance.
                                    I can't see how the axo-iso RB could do this...
                                    It's very simple...
                                    Does SketchUp crash when SketchUp is starting or when you try and run the RB ?
                                    I have it installed in v2017 and it works just fine !
                                      cyalumina109
                                      Hey TIG I have the same problem now, it crashes just after opening it
                                        Crashes immediately after opening are typically related to issues with the graphics drivers. With SketchUp 2017 and later, the graphics card must be up to the task of properly supporting OpenGL. What is the graphics card? Try updating the graphics drivers. If the graphics card is not up to the task, you may need to go back to SketchUp 2016 which has the option to dump rendering duties to the CPU.
                                        When you installed SketchUp, did you right click on the installer file and select Run as administrator from the context menu?
                                        • 2 / 2
