    Sketchup crashes when starting
    38 Posts 15 Posters 44.7k Views 15 Watching
      Uninstall 2013.
      Reinstall 2013, this time 'run as admin'.
      Report back...
      • G
        GhostFist
        Been there done that, same issue.
          Did you install it 'as admin'?
          Then set it to always 'run as admin'?
          πŸ˜•
          • G
            GhostFist
            yup, really scratching my head on this.
            • G
              GhostFist
              Problem resolved when rolling back the graphics driver
                Out of interest, what is/was your GC / drivers set ?
                It might help others to be forewarned...
                • G
                  GhostFist
                  Sketchup was running into problems using the Microsoft surface PRO after updating the graphics drivers from INTEL's site. Microsoft has written a custom driver for the surface pro's chipset and so a conflict was created. Removing Intel's generic driver and rolling back to Microsoft's resolved all issues.
                  • sketch3d.deS
                    sketch3d.de
                    @coulteri said:
                    I will try to upgrade the graphic card drivers.
                    you may want try also to disable the SU hardware acceleration (= OpenGL) from outside SU by using our concerning standalone support tool (Win only).
                    free for private & commercial usage (no adware/spyware/installation)
                    [update]
                    tool updated for being compatible with SU v2013/2014.
                    [/update]
                    hth,
                    Norbert
                      MILENIUMFALCON
                      hey tig i found the culprit rb folder crashing my sketchup and it was your axo+iso plugin. Any ideas how to make the plugin work? reply ASAP..
                      Thanks in advance.
                        I can't see how the axo-iso RB could do this...
                        It's very simple...
                        Does SketchUp crash when SketchUp is starting or when you try and run the RB ?
                        I have it installed in v2017 and it works just fine !
                        • C
                          cyalumina109
                          Hey TIG I have the same problem now, it crashes just after opening it
                            Crashes immediately after opening are typically related to issues with the graphics drivers. With SketchUp 2017 and later, the graphics card must be up to the task of properly supporting OpenGL. What is the graphics card? Try updating the graphics drivers. If the graphics card is not up to the task, you may need to go back to SketchUp 2016 which has the option to dump rendering duties to the CPU.
                            When you installed SketchUp, did you right click on the installer file and select Run as administrator from the context menu?
                            • 2 / 2
