    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    1001bit Extrude Problems...
    47 Posts 10 Posters 5.9k Views 10 Watching
    • X Offline
      xrok1
      An 'Edge' is a 'Line' in SUp-speak
      I know that often these tools need 'Curves', but then these are made from 'Edges'...
      The first combines edges with edges
      The next extrudes a face along edges
      The next uses faces as the basis of the extrusion
      The next 'lathes' the edges' curve
      The next 'lofts' the edge-sets' curves
      The next uses 2/3/4 edge curves as profiles/rails
      The next extrudes a face along replace ditto πŸ˜‰ profiles/rails
      The next makes a lattice using replace ditto πŸ˜‰ profiles/rails
      The next extrudes the edges along a vector
      i think you answered your own question. i think maybe its the word by or something in all the names i'm not sure but it just always makes me pause and wonder WTF it does. i think your above discriptions would make much better names. πŸ˜„ but its only my opinion and i by no means disrespect you or your abilities to please us all with your work. πŸ˜„
      β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        πŸ˜„
        A rose by any other name would smell as sweet...
        • X Offline
          xrok1
          TIG, thank god for the toolbar with the little pictures or i'd be totally lost. 😳
          For example, i wish I had a plugin which would allow me to extrude an edge rather than a face along a curved rail. Now that'd be cool!
          you can! use extrude edges by rails. pick the edge then the same rail twice, then the same edge again!
          or extrude edges by edges.
          but if you understood the naming you'd know that. πŸ˜‰
            πŸ‘
            You saved me some clicks Rocky, but it looks like i fall into the third class 😲
            • X Offline
              xrok1
              sorry TIG 🀣
              Or maybe a lathe like action around an axis?
              for this there's extrude edges by lathe. πŸ˜‰
                You should render that with a nice bump map πŸ˜‰
                • X Offline
                  xrok1
                  quit provoking me! πŸ˜†
                    Your Bump is maybe not enough prononced πŸ˜‰
                    Remember my old one πŸ’š Moi = Moment of Inspiration, a very cool prog! 😎
                    http://moi3d.com/gallery/images/Pod02.jpg
                      Tim Danaher
                      Cheers, xrok...
                      And TIG... you win an internet:
                      BTW, I'm assuming that weld.rb aligns the polyline so that all its segments are in the same direction?
                      Cheers,
                      Tim
                      http://vizarch.blogspot.com
                        Tim Danaher
                        So what would you suggest is the right e-by- plugin to sweep the attached profile round the curve? I want to see if I can get a smoother result than with the Follow Me tool (see my iPod Thread here: http://forums.sketchucation.com/viewtopic.php?f=15&t=27988)
                        iPod-touch-EEbyFace.skp
                        Cheers,
                        Tim
                        • X Offline
                          xrok1
                          no! πŸ˜† find the thread. weld connects all the segments together so they form 1. (polyline)
                            Weld.rb does sort the vertices of the selected lines/arcs so that the final curve [polyline] is ordered...
                              PS: Your axes are upside down ! πŸ˜’
                              • X Offline
                                xrok1
                                😳 is that what it was. πŸ˜† i couldn't get that model to anything i wanted it to. i think tim was actually testing us! πŸ‘Ώ well TIG tou passed, i failed 😳 πŸ˜†
                                  Tim Danaher
                                  @tig said:
                                  I'd use FollowMe for this as it's pretty simple ?[attachment=0:1o4wejcd]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1o4wejcd]
                                  Which is exactly what I'd done in the linked post... it's just that the rounding produced isn't too good: there are kinks at the corners that I'd like to get rid of.
                                  Cheers,
                                  Tim
                                    August
                                    "Take time to appreciate the fact that thorn bushes have roses."
                                    β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                                    [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                      There were no kinks in my plain FollowMe version ? Can you post a screen-shot ? πŸ˜•
                                        Tim Danaher
                                        Sure, TIG... here you go:
                                        I should probably attach the .skp too:
                                        iPod-touch-SUC.skp
                                        Cheers,
                                        Tim
                                        • G Offline
                                          gohch
                                          hi Tim,
                                          sorry for the VERY LATE reply to your question, 😳
                                          The extrude tool in 1001bit is meant for a different purpose actually, it's meant for extruding a profile through some curve slope, while maintaining 'upright' cross sectional profile.
                                          for example, ramps, handrails for spiral staircases etc.
                                          In order to do that, the sectional profile constantly twist itself to maintain as 'upright' as possible.
                                          This can be seen in the extrusion along a sloping curve(extruded entity on the right) below. The profile struggles to maintain upright always.
                                          This, however has some limitation: i.e. it cannot handle vertical edges, because vertical edges has no 'upright' cross section.
                                          hence the tool failed.
                                          In the event of a curved path that goes backwards on a vertical plane, the script will have to perform an immediate 180 degree abrupt twist to keep 'upright', in a single short segment, which will distort the entire profile. Hence it causes an error and stops there.
                                          The solution to this scenario depends a lot on what you want to achieve;
                                          1. to continue the profile -- that will lead to the original upwards direction becoming downwards after this turn.
                                          2. to start twisting much earlier before this backward curve, so that you have a smooth twisting transformation along this curve -- this will create a long stretch where a lot of segments are not maintained 'upright'
                                          Both the above doesn't agree with the original logic of this tool -- to maintain 'upright' in every segment.
                                          i haven't come across to what is the best way to handle vertical edges yet 😞
                                          I'm afraid the extrude along path tool is not really suitable for this purpose 😳
                                          • arail1A Offline
                                            arail1
                                            1001 Tools Extrude Selected Profile Along Selected Path is a very different tool than Follow Me.
                                            Follow Me extrudes a profile without reference to the world axis.
                                            In some cases that doesn't work - a good example is handrails.
                                            Handrails always have to be level to the ground (or level along the XY axis) no matter their pitch or direction.
                                            That's what 1001 Tools Extrude does.
                                            Notice the orientation of the top rectangle in these examples.
                                            I would take your chair frame and tilt it 30 degrees, extrude and then rotate it back into position.
                                            • 2 / 3
