    1001bit Extrude Problems...
    47 Posts 10 Posters 7.8k Views 10 Watching
      @arail1 said:
      Handrails always have to be level to the ground (or level along the XY axis) no matter their pitch or direction.
      That's what FollowMe and Keep would also do:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=16465
      • X Offline
        xrok1
        @arail1 said:
        1001 Tools Extrude
        I would take your chair frame and tilt it 30 degrees, extrude and then rotate it back into position.
        that works perfectly! πŸ˜„ i wonder if Goh might think of modifying his script so that if it hit a vertical it will rotate the profile automatically, continue on, then put it back in its original orientation when its done? πŸ˜‰ or use whatever method FAK and extrude tools use.
        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        • arail1A Offline
          arail1
          You're absolutely right. I wasn't aware of that ruby - I need to be more up to date with SketchUp. I'm spending too much time over there in modoland. Thanks
          • Tim DanaherT Offline
            Tim Danaher
            @arail1 said:
            Notice the orientation of the top rectangle in these examples.
            Hah! Lateral thinking at its best! I love it!
            Cheers,
            Tim
            http://vizarch.blogspot.com
              Never think vertically πŸ˜† That was evident! πŸ‘
              So that's working in 1001 πŸ‘
              Super trick! 😎
              • G Offline
                gohch
                That's a really brilliant approach. πŸ‘ πŸ‘ πŸ‘
                I've never thought of solving it this way!
                Actually i couldn't figure out what is the best way to handle vertical that turns backwards because the upper rail will surely turn upside down....
                  But that works only if any "little segments" of curves are no vertical! πŸ˜‰
                  And this is not evident if you have some curves corners!
                  • 3 / 3
