    1001bit Extrude Problems...
    47 Posts 10 Posters 9.6k Views 10 Watching
    • X Offline
      xrok1
      @tim danaher said:
      BTW, I'm assuming that weld.rb aligns the polyline so that all its segments are in the same direction?
      no! πŸ˜† find the thread. weld connects all the segments together so they form 1. (polyline)
        Weld.rb does sort the vertices of the selected lines/arcs so that the final curve [polyline] is ordered...
          PS: Your axes are upside down ! πŸ˜’
          • X Offline
            xrok1
            😳 is that what it was. πŸ˜† i couldn't get that model to anything i wanted it to. i think tim was actually testing us! πŸ‘Ώ well TIG tou passed, i failed 😳 πŸ˜†
            • Tim DanaherT Offline
              Tim Danaher
              @tig said:
              I'd use FollowMe for this as it's pretty simple ?[attachment=0:1o4wejcd]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1o4wejcd]
              Which is exactly what I'd done in the linked post... it's just that the rounding produced isn't too good: there are kinks at the corners that I'd like to get rid of.
              Cheers,
              Tim
              http://vizarch.blogspot.com
                August
                @tig said:
                A rose by any other name would smell as sweet...
                "Take time to appreciate the fact that thorn bushes have roses."
                β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                  There were no kinks in my plain FollowMe version ? Can you post a screen-shot ? πŸ˜•
                    Tim Danaher
                    Sure, TIG... here you go:
                    I should probably attach the .skp too:
                    iPod-touch-SUC.skp
                    Cheers,
                    Tim
                      gohch
                      hi Tim,
                      sorry for the VERY LATE reply to your question, 😳
                      The extrude tool in 1001bit is meant for a different purpose actually, it's meant for extruding a profile through some curve slope, while maintaining 'upright' cross sectional profile.
                      for example, ramps, handrails for spiral staircases etc.
                      In order to do that, the sectional profile constantly twist itself to maintain as 'upright' as possible.
                      This can be seen in the extrusion along a sloping curve(extruded entity on the right) below. The profile struggles to maintain upright always.
                      This, however has some limitation: i.e. it cannot handle vertical edges, because vertical edges has no 'upright' cross section.
                      hence the tool failed.
                      In the event of a curved path that goes backwards on a vertical plane, the script will have to perform an immediate 180 degree abrupt twist to keep 'upright', in a single short segment, which will distort the entire profile. Hence it causes an error and stops there.
                      The solution to this scenario depends a lot on what you want to achieve;
                      1. to continue the profile -- that will lead to the original upwards direction becoming downwards after this turn.
                      2. to start twisting much earlier before this backward curve, so that you have a smooth twisting transformation along this curve -- this will create a long stretch where a lot of segments are not maintained 'upright'
                      Both the above doesn't agree with the original logic of this tool -- to maintain 'upright' in every segment.
                      i haven't come across to what is the best way to handle vertical edges yet 😞
                      I'm afraid the extrude along path tool is not really suitable for this purpose 😳
                      • arail1A Offline
                        arail1
                        1001 Tools Extrude Selected Profile Along Selected Path is a very different tool than Follow Me.
                        Follow Me extrudes a profile without reference to the world axis.
                        In some cases that doesn't work - a good example is handrails.
                        Handrails always have to be level to the ground (or level along the XY axis) no matter their pitch or direction.
                        That's what 1001 Tools Extrude does.
                        Notice the orientation of the top rectangle in these examples.
                        I would take your chair frame and tilt it 30 degrees, extrude and then rotate it back into position.
                          That's what FollowMe and Keep would also do:
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=16465
                          • X Offline
                            xrok1
                            @arail1 said:
                            1001 Tools Extrude
                            that works perfectly! πŸ˜„ i wonder if Goh might think of modifying his script so that if it hit a vertical it will rotate the profile automatically, continue on, then put it back in its original orientation when its done? πŸ˜‰ or use whatever method FAK and extrude tools use.
                            • arail1A Offline
                              arail1
                              You're absolutely right. I wasn't aware of that ruby - I need to be more up to date with SketchUp. I'm spending too much time over there in modoland. Thanks
                                Tim Danaher
                                Hah! Lateral thinking at its best! I love it!
                                Cheers,
                                Tim
                                  Never think vertically πŸ˜† That was evident! πŸ‘
                                  So that's working in 1001 πŸ‘
                                  Super trick! 😎
                                    gohch
                                    That's a really brilliant approach. πŸ‘ πŸ‘ πŸ‘
                                    I've never thought of solving it this way!
                                    Actually i couldn't figure out what is the best way to handle vertical that turns backwards because the upper rail will surely turn upside down....
                                      But that works only if any "little segments" of curves are no vertical! πŸ˜‰
                                      And this is not evident if you have some curves corners!
                                      • 2 / 3
