    1001bit Extrude Problems...
    47 Posts 10 Posters 9.9k Views 10 Watching
      extrude tools are all named weird
      yes πŸ˜„
        @ Tim
        You see that the calculate is beginning when you can't move the blue cross with the mouse after the click on the beginning curve!
        That is not a "torsion" here πŸ˜‰
        PS Sorry I have not MAC and absolut know how it works πŸ’š
        But you must have the Help line!
          • X
            xrok1
            don't pretend you didn't know 🀣
              πŸ˜‰
              The tools
              "Extrude"
              "Edges"
              "by"
              "something"
              Edges
              Face
              Faces
              Lathe
              Loft
              Rails
              RailsByFace
              RailsToLattice
              Vector
              As they are a 'set' I have kept the naming quite consistent...
              An 'Edge' is a 'Line' in SUp-speak
              I know that often these tools need 'Curves', but then these are made from 'Edges'...
              The first combines edges with edges
              The next extrudes a face along edges
              The next uses faces as the basis of the extrusion
              The next 'lathes' the edges' curve
              The next 'lofts' the edge-sets' curves
              The next uses 2/3/4 edge curves as profiles/rails
              The next extrudes a face along ditto
              The next makes a lattice using ditto
              The next extrudes the edges along a vector
              How better to describe them ???
              πŸ˜’
                They make perfect sense to me!
                For example, i wish I had a plugin which would allow me to extrude an edge rather than a face along a curved rail. Now that'd be cool!
                A sort of Extrude Edge by Rail tool! Hey I could even chose to extrude faces too? Or maybe a lathe like action around an axis?
                Damn that'd cool 😎
                • X
                  xrok1
                  The next extrudes a face along replace ditto πŸ˜‰ profiles/rails
                  The next makes a lattice using replace ditto πŸ˜‰ profiles/rails
                  i think you answered your own question. i think maybe its the word by or something in all the names i'm not sure but it just always makes me pause and wonder WTF it does. i think your above discriptions would make much better names. πŸ˜„ but its only my opinion and i by no means disrespect you or your abilities to please us all with your work. πŸ˜„
                    πŸ˜„
                    A rose by any other name would smell as sweet...
                    • X
                      xrok1
                      TIG, thank god for the toolbar with the little pictures or i'd be totally lost. 😳
                      you can! use extrude edges by rails. pick the edge then the same rail twice, then the same edge again!
                      or extrude edges by edges.
                      but if you understood the naming you'd know that. πŸ˜‰
                        πŸ‘
                        You saved me some clicks Rocky, but it looks like i fall into the third class 😲
                        • X
                          xrok1
                          sorry TIG 🀣
                          for this there's extrude edges by lathe. πŸ˜‰
                            You should render that with a nice bump map πŸ˜‰
                            • X
                              xrok1
                              quit provoking me! πŸ˜†
                                Your Bump is maybe not enough prononced πŸ˜‰
                                Remember my old one πŸ’š Moi = Moment of Inspiration, a very cool prog! 😎
                                http://moi3d.com/gallery/images/Pod02.jpg
                                • Tim DanaherT
                                  Tim Danaher
                                  Cheers, xrok...
                                  And TIG... you win an internet:
                                  BTW, I'm assuming that weld.rb aligns the polyline so that all its segments are in the same direction?
                                  Cheers,
                                  Tim
                                  http://vizarch.blogspot.com
                                  • Tim DanaherT
                                    Tim Danaher
                                    So what would you suggest is the right e-by- plugin to sweep the attached profile round the curve? I want to see if I can get a smoother result than with the Follow Me tool (see my iPod Thread here: http://forums.sketchucation.com/viewtopic.php?f=15&t=27988)
                                    iPod-touch-EEbyFace.skp
                                    Cheers,
                                    Tim
                                    • X
                                      xrok1
                                      no! πŸ˜† find the thread. weld connects all the segments together so they form 1. (polyline)
                                        Weld.rb does sort the vertices of the selected lines/arcs so that the final curve [polyline] is ordered...
                                          PS: Your axes are upside down ! πŸ˜’
                                          • X
                                            xrok1
                                            😳 is that what it was. πŸ˜† i couldn't get that model to anything i wanted it to. i think tim was actually testing us! πŸ‘Ώ well TIG tou passed, i failed 😳 πŸ˜†
                                            • 2 / 3
