    Axis- this way or that?
    13 Posts 7 Posters 914 Views 7 Watching
      jeff hammond
      setting up a new template and i'm finally going to ask about this tiny thing that i've been curious about for a few years now πŸ˜„
      is there any reason why the dotted X&Y lines should face one way vs. the other?
      i've always had my templates open in this fashion..
      ...but i'll switch to this if there's any reason better than personal preference.
      dotdotdot
        solid lines indicate positive axis, dotted indicate negative axis.
          jeff hammond
          hmm πŸ˜„
          ok, i understand that with the Z axis but in 2D it doesn't make any difference (to me).. or does it?
          dotdotdot
            jeff hammond
            ok.. i'm just going to keep it how i've been doing it.. that way, if i have to paste in place from an older model then it will show up as expected.
            dotdotdot
              mac1
              This is what is called a right hand coordinate system
              X x Y=z
              y x z=x
              z x x = y
              • G Offline
                In fact, it could be "all the same" whether to look from this or that direction however from a "practical" point of view, your first image would be more handy as when setting up standard views, that is where SU will show your model's "Front"
                  In your images you are just looking at the origin from opposite directions [the back rather than the front] - with Z 'up' in both of them [blue].
                  It would be possible to be looking at this completely upside down - but then orbiting etc gets confused as SUp assume a certain amount of vertically in your day to day model viewing πŸ˜„
                  • W Offline
                    wind-borne
                    If you use axes as your orientation, by default solid green is N making solid red E.
                    I like to start with North towards the top and always have consistent reference lines when orbiting.
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                      jeff hammond
                      ah, ok.. so yeah, i've been doing it (by pure luck) the way i would of chosen to if i knew this info..
                      my template opens in this orientation then i always start drawing in the quadrant as shown:
                      if i switch to top view then it looks like this: (which is the orientation i want it to be in)
                      thanks for the replies.. my tiny question from the past couple of years has been resolved πŸ˜„
                      dotdotdot
                        jeff hammond
                        and yes, messing with the shadows/time of day does correspond with solid green being north.
                        dotdotdot
                          mikeewilly
                          On a related note: I would like to have the standard views be oriented to the axes. As I design additions to existing structures, sometimes the orientation of the addition isn't the same as the existing structure. So when I change the axes to orient to the new structure, the standard views remain where they were when the drawing was initiated, which is VERY unhandy when trying to make construction drawings of the addition.
                          Any ideas or plugins out there?
                          Thanks,
                          Mike
                            Chris to the rescue: http://forums.sketchucation.com/viewtopic.php?f=323&t=19168 πŸ˜„
                              mikeewilly
                              Thanks for the pointer. That's what I was looking for.
                              Cheers,
                              Mike
