    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.3k Views 175 Watching
      @rock1 said:
      this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials ๐Ÿ˜’
      You might find it helpful to learn the basic tool set first. And then search through the forum because there's lots of information on using TIG's Extrude Tools. He did instructions for all of the tools in individual threads.
        rock1
        I'm unable to have the first button, don't know why.
        http://i.imgur.com/xFvTG.jpg
        This has been a problem since a long time. I have got now windows 7 ultimate but the problem is still there. I did a fresh download of this set, overwrote the old extrude tools files but the problem is still there. ๐Ÿ˜•
        Signature removed by SCF Admin
          There are only ever 11 buttons - there are only 11 extrudeEdgesBy...rb files!!!
          I suspect that you have put one of the files into two auto-loading locations or have two copies with slightly different names in Plugins - so something is loading twice but the 1st time its icon files are not found - SO... what is the first button ? See its Tooltip etc or look in the Plugins>ExtrusionTools... for a submenu duplicate.
          Temporarily move all of the 11 'good' extrudeEdgesBy...rb files into another folder and restart SUp [leave the #extrusionToolbar.rb in placeso the toolbar MIGHT get made]. Then you can track down the culprit - perhaps something like 2x extrudeEdgesByEdges.rb ??
          Let us know when you've fixed it.
            rock1
            Whoa what a shot TIG!, bingo, its' the one extrude edgesbyedges, WTH it's duplicated ๐Ÿ˜† !!!. ๐Ÿ˜ฎ I'll try to solve. i'm getting a duplicate in plugins menu man!! ๐Ÿ˜ฒ
              rock1
              i am unable to solve this problem. what should i do โ“
                Have you got two brain-cells to rub together ๐Ÿ˜’
                You have got two files with similar names loading, that then add the same tool twice.
                So simply look through the contents of Plugins.
                Find these two files and open/read them both with Notepad.exe
                The one called "extrudeEdgesByEdges.rb" is the one to keep - it's from the zipped set [it says 'Version 3.0' in its notes]
                The other one that's maybe 'older' and/or just has 'another similar name' needs removing.
                There are several files in Plugins with similar names but only two of the 11 [in your case 12!] are the ones you need to worry on...
                I can't do this for you - you must help yourself here - be resilient...
                  Here's an update
                  http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  Two tools now have 'Quad Face' options to complement thomthom's new Quad-Tool
                  ExtrudeEdgesByRails http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                  ExtrudeEdgesByLoft http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
                  The lingvo files have also been updated to suit.
                    Sweet! More quad tools! ๐Ÿ˜„
                    • Rich O BrienR Online
                      Error on startup...
                      Error Loading File extrudeEdgesByRails.rb
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;163; syntax error, unexpected '='
                        Error on startup...
                        > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;[b]163[/b]; syntax error, unexpected '='
                        ๐Ÿ˜’ I somehow managed to duplicate a line below '=end' in the guidance notes as I saved the file...
                        Here's the updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        Sorry ๐Ÿ˜ณ ... but the 8 of you who downloaded it so far do need to do it again ๐Ÿ˜ฒ
                        More haste, less speed... as the English proverb goes...
                          Here's a maintenance update which includes new ES lingvo files by deFisto with minor idiom corrections etc, and a minor 'db' correction to EEbyLathe to include the start_operation name...
                            thank you ๐Ÿ‘
                              Here's another update...
                              It now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
                              • srxS Offline
                                srx
                                Thanks! Nice to see you working as a team ๐Ÿ˜„ ๐Ÿ‘
                                www.saurus.rs
                                  Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  EEbyLathe v3.5 Fixed Picked-Angle's messy undo; Smoothed-edges now stop @90ยบ.
                                  • jeff hammondJ Offline
                                    jeff hammond
                                    oops ๐Ÿ˜ณ
                                    i forgot to say thanks earlier for this update..
                                    much better !
                                    thank you!
                                    dotdotdot
                                      EEbyRails and EEbyLoft have been updated so that the 'Quad Faces' option meets Thomthom's updated spec for this type of face...
                                      • P Offline
                                        PeterF
                                        I've just installed the collection but it isn't working properly. The toolbar doesn't appear and the EbyEdges tool doesn't work. I haven't tried the others out yet. Is this just me? I've installed it by putting the .rb files in the main plugins folder and the tigtools folder in there as well. Is that right?
                                          Yes. ๐Ÿ˜•
                                          The TIGtools folder contains lots of support files too.
                                          Are you sure all of the files are properly inside Plugins ?
                                          No 'Compatibility Files' issues ??
                                          The one starting with # is needed to make the toolbar etc.
                                          You must activate the toolbar from View > Toolbars the first time it's loaded...
                                            altab
                                            Hi, thanks aagain for this excellent tools
                                            Is it possible to use extrude edge by loft by using lines and curves instead of curves exclusively,
                                            If it is not possible how can I recreate the line using a curve ?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
