    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 968.2k Views 175 Watching
      Error on startup...
      Error Loading File extrudeEdgesByRails.rb
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;163; syntax error, unexpected '='
        Error on startup...
        > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;[b]163[/b]; syntax error, unexpected '='
        😒 I somehow managed to duplicate a line below '=end' in the guidance notes as I saved the file...
        Here's the updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Sorry 😳 ... but the 8 of you who downloaded it so far do need to do it again 😲
        More haste, less speed... as the English proverb goes...
          Here's a maintenance update which includes new ES lingvo files by deFisto with minor idiom corrections etc, and a minor 'db' correction to EEbyLathe to include the start_operation name...
            thank you 👍
              Here's another update...
              It now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
              • srxS Offline
                srx
                Thanks! Nice to see you working as a team 😄 👍
                www.saurus.rs
                  Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  EEbyLathe v3.5 Fixed Picked-Angle's messy undo; Smoothed-edges now stop @90º.
                  • jeff hammondJ Offline
                    oops 😳
                    i forgot to say thanks earlier for this update..
                    much better !
                    thank you!
                      EEbyRails and EEbyLoft have been updated so that the 'Quad Faces' option meets Thomthom's updated spec for this type of face...
                        PeterF
                        I've just installed the collection but it isn't working properly. The toolbar doesn't appear and the EbyEdges tool doesn't work. I haven't tried the others out yet. Is this just me? I've installed it by putting the .rb files in the main plugins folder and the tigtools folder in there as well. Is that right?
                          Yes. 😕
                          The TIGtools folder contains lots of support files too.
                          Are you sure all of the files are properly inside Plugins ?
                          No 'Compatibility Files' issues ??
                          The one starting with # is needed to make the toolbar etc.
                          You must activate the toolbar from View > Toolbars the first time it's loaded...
                            altab
                            Hi, thanks aagain for this excellent tools
                            Is it possible to use extrude edge by loft by using lines and curves instead of curves exclusively,
                            If it is not possible how can I recreate the line using a curve ?
                              PeterF
                              Ok, I've got the toolbar, but when I try to use the EbyEdge tool, for about 15 - 20mins nothing happens. My computer is normally quite fast - is it meant to take that long?
                                Run it with the Ruby Console open and post any error messages.
                                Are you sure you want to use this too?
                                It has quite specific results.
                                Perhaps EEbyRails might be what you want... 😕
                                  Fredo's CurviLoft might work with plain edges... BUT most of my EEby... tools usually require 'Curves' to be selected... to make a collection of edges into a 'curve' use weld.rb, it's freely available from Smustard.com...
                                    altab
                                    I've ended using curviloft, the weld tool couldn't manage to get my lines into curves
                                      Meisterdrow
                                      I have the toolbar, but nothing happens if i want to use a function except the popup-windows.
                                      I am getting the following error from Ruby-Console:
                                      Error: #<TypeError: reference to deleted Group>
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in entities' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in make_mesh'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:286:in `onLButtonDown
                                      Can anyone help me? Thanks in advance!
                                        The error you show is when you choose to intersect the mesh with itself. What happens if you don't do that [say No!]...
                                        Can you post the SKP that's causing the issue and some instructions on the steps you are taking to get the error, which I can't reproduce... 😕
                                          Meisterdrow
                                          Hi TIG,
                                          thank you for your fast answer! I will give a more detailed description: I had to reinstall Sketchup and because of that also your plugin. Since that reinstallation the whole plugin is not working anymore and I can’t figure out why (because I installed it the same way as before). No matter which function of the plugin I use, I get no result.
                                          I get the error message I posted every time when I press “intersect with mesh”. When I press anything else nothing happens at all (no matter which of the functions I use). When I use the function “Extrude edges by rails” for example I get another error message:
                                          EEE
                                          undefined method `transform!' for nil:NilClass
                                          I added two screenshots, I don’t know if that helps.
                                          • majidM Offline
                                            majid
                                            dear Tig
                                            I installed this set on a fresh copy of Su but some tool are not working with no error message! just it highlights ( and recolor) curves!
                                            Majid
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
