    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      Have you got two brain-cells to rub together 😒
      You have got two files with similar names loading, that then add the same tool twice.
      So simply look through the contents of Plugins.
      Find these two files and open/read them both with Notepad.exe
      The one called "extrudeEdgesByEdges.rb" is the one to keep - it's from the zipped set [it says 'Version 3.0' in its notes]
      The other one that's maybe 'older' and/or just has 'another similar name' needs removing.
      There are several files in Plugins with similar names but only two of the 11 [in your case 12!] are the ones you need to worry on...
      I can't do this for you - you must help yourself here - be resilient...
        Here's an update
        http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Two tools now have 'Quad Face' options to complement thomthom's new Quad-Tool
        ExtrudeEdgesByRails http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
        ExtrudeEdgesByLoft http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
        The lingvo files have also been updated to suit.
          Sweet! More quad tools! 😄
            Error on startup...
            Error Loading File extrudeEdgesByRails.rb
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;163; syntax error, unexpected '='
              Error on startup...
              > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;[b]163[/b]; syntax error, unexpected '='
              😒 I somehow managed to duplicate a line below '=end' in the guidance notes as I saved the file...
              Here's the updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              Sorry 😳 ... but the 8 of you who downloaded it so far do need to do it again 😲
              More haste, less speed... as the English proverb goes...
                Here's a maintenance update which includes new ES lingvo files by deFisto with minor idiom corrections etc, and a minor 'db' correction to EEbyLathe to include the start_operation name...
                  thank you 👍
                    Here's another update...
                    It now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
                    • srxS
                      srx
                      Thanks! Nice to see you working as a team 😄 👍
                      www.saurus.rs
                        Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        EEbyLathe v3.5 Fixed Picked-Angle's messy undo; Smoothed-edges now stop @90º.
                        • jeff hammondJ
                          oops 😳
                          i forgot to say thanks earlier for this update..
                          much better !
                          thank you!
                            EEbyRails and EEbyLoft have been updated so that the 'Quad Faces' option meets Thomthom's updated spec for this type of face...
                            • P
                              PeterF
                              I've just installed the collection but it isn't working properly. The toolbar doesn't appear and the EbyEdges tool doesn't work. I haven't tried the others out yet. Is this just me? I've installed it by putting the .rb files in the main plugins folder and the tigtools folder in there as well. Is that right?
                                Yes. 😕
                                The TIGtools folder contains lots of support files too.
                                Are you sure all of the files are properly inside Plugins ?
                                No 'Compatibility Files' issues ??
                                The one starting with # is needed to make the toolbar etc.
                                You must activate the toolbar from View > Toolbars the first time it's loaded...
                                  altab
                                  Hi, thanks aagain for this excellent tools
                                  Is it possible to use extrude edge by loft by using lines and curves instead of curves exclusively,
                                  If it is not possible how can I recreate the line using a curve ?
                                  • P
                                    PeterF
                                    Ok, I've got the toolbar, but when I try to use the EbyEdge tool, for about 15 - 20mins nothing happens. My computer is normally quite fast - is it meant to take that long?
                                      Run it with the Ruby Console open and post any error messages.
                                      Are you sure you want to use this too?
                                      It has quite specific results.
                                      Perhaps EEbyRails might be what you want... 😕
                                        Fredo's CurviLoft might work with plain edges... BUT most of my EEby... tools usually require 'Curves' to be selected... to make a collection of edges into a 'curve' use weld.rb, it's freely available from Smustard.com...
                                          altab
                                          I've ended using curviloft, the weld tool couldn't manage to get my lines into curves
                                            Meisterdrow
                                            I have the toolbar, but nothing happens if i want to use a function except the popup-windows.
                                            I am getting the following error from Ruby-Console:
                                            Error: #<TypeError: reference to deleted Group>
                                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in entities' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in make_mesh'
                                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:286:in `onLButtonDown
                                            Can anyone help me? Thanks in advance!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
