    SU gone wild!!!
    renderpluginsextensions
    19 Posts 5 Posters 3.1k Views 5 Watching
    • troyhomeT
      troyhome
      On the Mac, SU Pro is acting very weird!
      First, when i press space bar, instead of the select tool, model info comes up- even if i'm typing in a different program while SU is open!!!!
      Second, if i quit a program, SU wants to quit also!!!
      very frustrating!!!!
      see a video of thispressing space bar and quitting another program makes SU act crazy
      Running SU 7.1.5803 on MBPro, OSX 10.6.2.
      IOviz.com
      SU Pro 2024 PC
      • troyhomeT
        troyhome
        Any ideas? Has anyone been able to reproduce this behavior?
        IOviz.com
        SU Pro 2024 PC
        • DavidBoulderD
          DavidBoulder
          I assume you have tried a restart on the computer with same results. Does seem odd.
          David Goldwasser
          OpenStudio Developer
          • troyhomeT
            troyhome
            restart didn't help.
            IOviz.com
            SU Pro 2024 PC
            • troyhomeT
              troyhome
              SketchUp 7 (7.1.5803) Mac osx 10.6.2 build 10c540 macbook pro 17"
              I believe it's an issue with Vray- i am a beta tester.
              I didn't notice this until i upgraded to 7.1:
              When in SU, pressing the spacebar brings up the model info dialog box as activated by the icon in the lower left hand corner of the su screen.
              Additionally, and much more sinister, SU responds to keystrokes when i am in other programs. If i press the spacebar in another program, it activates the model info dialog in SU. Likewise if i quite a program, SU wants to quit also.
              The keystroke issue goes away when i removed Vray for SU mac.
              The spacebar issue remains regardless. This is a SketchUp issue that needs to be addressed please!
              IOviz.com
              SU Pro 2024 PC
              • thomthomT
                hm... wonder if I read somewhere about that... but thought it was a while ago. You got the latest version installed?
                Try to uninstall the VfSU beta and see if the problem is still there. If it is, submit a bug ticket to ASGVis.
                • troyhomeT
                  troyhome
                  i did uninstall it and i have submitted a bug ticket to ASGVis; i thought i had the latest version... vfsu 1.48.50 is that right?
                  IOviz.com
                  SU Pro 2024 PC
                  • thomthomT
                    .52 is. They kick out released pretty fast. I some times don't get time to install a release before there's a new one.
                    • troyhomeT
                      troyhome
                      ah ha. thanks. they haven't sent me the link for that one yet. guess i'll wait around to hear back from them πŸ˜‰
                      thanks, thomthom
                      update:
                      i just got .52 and will try it out asap
                      IOviz.com
                      SU Pro 2024 PC
                      • A
                        Arkman
                        Did you figure this problem out? I have the same issue and its driving me nuts.
                        • troyhomeT
                          troyhome
                          Apparently it is fixed by disabling the Mac Universal Access features under the systems panel. Go figure.
                          IOviz.com
                          SU Pro 2024 PC
                          • Tim DanaherT
                            Tim Danaher
                            I'm having exactly this problem.
                            Unfortunately, since I've only got one arm, Universal Access is rather important to me.
                            Cheers,
                            Tim
                            http://vizarch.blogspot.com
                            • troyhomeT
                              troyhome
                              I would try turning on what you need and turning off what you might not need and see if it works. In either case- this is something that needs to be addressed before ASVG should accept money for their product that is directed at Mac users.
                              IOviz.com
                              SU Pro 2024 PC
                              • Tim DanaherT
                                Tim Danaher
                                I only have Sticky Keys enabled. But turning off 'Enable Access for Assistive Devices' seems to do the trick. I think. Trouble is, that messes up my window switcher, 'witch' relies on that function to work.
                                What's ASVG, BTW? I'm on the beta team, so have sent a bug report about this, too.
                                Cheers,
                                Tim
                                • thomthomT
                                  VfSU Beta issues should be kept in the ASGVis beta forum.
                                  • A
                                    Arkman
                                    Thanks! I dont have any plug ins for sketchup but found this on a google search. It worked for me!
                                    • Tim DanaherT
                                      Tim Danaher
                                      Here's the reply I received from Google QA ---
                                      Doesn't seem to do anything, though...
                                      Yea, I've complained about this and filed the bug, too. I have two arms and it bugs me, so I'm sure it's worse for you. I always have System Preferences->Keyboard & Mouse->Keyboard Shortcuts tab's "All Controls" set on. You can toggle on and off with Control-F7.
                                      Here's the workaround that I use: rather than (Solution 1) temporarily toggle Ctrl-F7, it's easier for me to (Solution 2) hit tab four times as the first thing I do when I open a SketchUp file, which will place the little blue halo onto the select tool and off the Model Info button on the bottom left of the window.
                                      Cheers,
                                      Tim
                                      • troyhomeT
                                        troyhome
                                        Good ideas for workarounds- thanks!
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • Tim DanaherT
                                          Tim Danaher
                                          Troy --- if you can tell me what those workarounds are supposed to do and how they work, I'd be extremely grateful...
                                          Cheers,
                                          Tim
