    SU gone wild!!!
    renderpluginsextensions
    19 Posts 5 Posters 2.6k Views 5 Watching
      troyhome
      ah ha. thanks. they haven't sent me the link for that one yet. guess i'll wait around to hear back from them πŸ˜‰
      thanks, thomthom
      update:
      i just got .52 and will try it out asap
      IOviz.com
      SU Pro 2024 PC
        Arkman
        Did you figure this problem out? I have the same issue and its driving me nuts.
          troyhome
          Apparently it is fixed by disabling the Mac Universal Access features under the systems panel. Go figure.
          IOviz.com
          SU Pro 2024 PC
          • Tim DanaherT Offline
            Tim Danaher
            I'm having exactly this problem.
            Unfortunately, since I've only got one arm, Universal Access is rather important to me.
            Cheers,
            Tim
            http://vizarch.blogspot.com
              troyhome
              I would try turning on what you need and turning off what you might not need and see if it works. In either case- this is something that needs to be addressed before ASVG should accept money for their product that is directed at Mac users.
              IOviz.com
              SU Pro 2024 PC
                Tim Danaher
                I only have Sticky Keys enabled. But turning off 'Enable Access for Assistive Devices' seems to do the trick. I think. Trouble is, that messes up my window switcher, 'witch' relies on that function to work.
                What's ASVG, BTW? I'm on the beta team, so have sent a bug report about this, too.
                Cheers,
                Tim
                  VfSU Beta issues should be kept in the ASGVis beta forum.
                    Arkman
                    Thanks! I dont have any plug ins for sketchup but found this on a google search. It worked for me!
                      Tim Danaher
                      Here's the reply I received from Google QA ---
                      Doesn't seem to do anything, though...
                      Yea, I've complained about this and filed the bug, too. I have two arms and it bugs me, so I'm sure it's worse for you. I always have System Preferences->Keyboard & Mouse->Keyboard Shortcuts tab's "All Controls" set on. You can toggle on and off with Control-F7.
                      Here's the workaround that I use: rather than (Solution 1) temporarily toggle Ctrl-F7, it's easier for me to (Solution 2) hit tab four times as the first thing I do when I open a SketchUp file, which will place the little blue halo onto the select tool and off the Model Info button on the bottom left of the window.
                      Cheers,
                      Tim
                        troyhome
                        Good ideas for workarounds- thanks!
                        IOviz.com
                        SU Pro 2024 PC
                          Tim Danaher
                          Troy --- if you can tell me what those workarounds are supposed to do and how they work, I'd be extremely grateful...
                          Cheers,
                          Tim
