    SU gone wild!!!
    renderpluginsextensions
    19 Posts 5 Posters 2.6k Views 5 Watching
      .52 is. They kick out released pretty fast. I some times don't get time to install a release before there's a new one.
        troyhome
        ah ha. thanks. they haven't sent me the link for that one yet. guess i'll wait around to hear back from them πŸ˜‰
        thanks, thomthom
        update:
        i just got .52 and will try it out asap
        IOviz.com
        SU Pro 2024 PC
          Arkman
          Did you figure this problem out? I have the same issue and its driving me nuts.
            troyhome
            Apparently it is fixed by disabling the Mac Universal Access features under the systems panel. Go figure.
            IOviz.com
            SU Pro 2024 PC
            • Tim DanaherT Offline
              Tim Danaher
              I'm having exactly this problem.
              Unfortunately, since I've only got one arm, Universal Access is rather important to me.
              Cheers,
              Tim
              http://vizarch.blogspot.com
                troyhome
                I would try turning on what you need and turning off what you might not need and see if it works. In either case- this is something that needs to be addressed before ASVG should accept money for their product that is directed at Mac users.
                IOviz.com
                SU Pro 2024 PC
                  Tim Danaher
                  I only have Sticky Keys enabled. But turning off 'Enable Access for Assistive Devices' seems to do the trick. I think. Trouble is, that messes up my window switcher, 'witch' relies on that function to work.
                  What's ASVG, BTW? I'm on the beta team, so have sent a bug report about this, too.
                  Cheers,
                  Tim
                    VfSU Beta issues should be kept in the ASGVis beta forum.
                      Arkman
                      Thanks! I dont have any plug ins for sketchup but found this on a google search. It worked for me!
                        Tim Danaher
                        Here's the reply I received from Google QA ---
                        Doesn't seem to do anything, though...
                        Yea, I've complained about this and filed the bug, too. I have two arms and it bugs me, so I'm sure it's worse for you. I always have System Preferences->Keyboard & Mouse->Keyboard Shortcuts tab's "All Controls" set on. You can toggle on and off with Control-F7.
                        Here's the workaround that I use: rather than (Solution 1) temporarily toggle Ctrl-F7, it's easier for me to (Solution 2) hit tab four times as the first thing I do when I open a SketchUp file, which will place the little blue halo onto the select tool and off the Model Info button on the bottom left of the window.
                        Cheers,
                        Tim
                          troyhome
                          Good ideas for workarounds- thanks!
                          IOviz.com
                          SU Pro 2024 PC
                            Tim Danaher
                            Troy --- if you can tell me what those workarounds are supposed to do and how they work, I'd be extremely grateful...
                            Cheers,
                            Tim
