    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 236.2k Views 51 Watching
      Ah Damned! 😳 Thx 👍 (fixed) ☀
      With esperanto that will be more easy just one language 😒
        Ah Damned! 😳 Thx 👍
        There is already one World language - unfortunately it's English [and it's American too!] 😉
        Il y a déjà une langue du monde - c'est malheureusement anglais [et aussi c'est Américain!]
        Estas jam unu Monda lingvo - bedaŭrinde ĝi estas Angla [kaj tio estas Amerika ankaŭ!]
          c.plassais
          Good Works Pilou...............for the translation OF COURSE!!!
                       :facepunch:  :facepunch:  :facepunch:  :facepunch: :facepunch: :facepunch: :facepunch:
          c.plassais
            @C.plassais: sorry a very hard hyperactive end of year 💚
            See you soon next year! 😉
            [flash=500,405:1je4n8r4]http://www.youtube.com/v/o9698TqtY4A[/flash:1je4n8r4]
            • MALAISEM Offline
              MALAISE
              Oh Guys, I miss a lot beeing on travel for the last 15 days.
              Excellent work, I 'll use it very fast for technical explanations 😄
              MALAISE
              • X Offline
                xrok1
                great plugin, thanks. if you could rename this "Exploded View" or "Exploded Model Viewer" or similiar, it would be much more precise and easier to find. 😉
                “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  Edit the script with a plain text editor - like Notepad.exe [osa] - and replace any 'French' text inside "" with your 'English' translation[s]. Keep a copy in case you screw up...
                  You can adjust a script to say whatever you want.... 🤓
                    you speak about the title of the tread?
                    • X Offline
                      xrok1
                      yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
                        He got a point..
                        • X Offline
                          xrok1
                          it would make it a little more clear what the plugin is for as well. 😉
                            Done and tested with the search Engine ☀
                            No someone can find it by the title and by your post 😉
                              Anyone experiencing Bugsplats with SU7.1 and this plugin?
                              Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                              I know i have the components nested in a component but use this plugin when not nested
                              CherryMax Rivet.skp
                                Stephan
                                Hello,
                                Same problem for me with SU7.16860, I get a Bugsplat each time I try to use it. 😕
                                Any idea?
                                Rgds,
                                Stephan
                                • K Offline
                                  kostas_designer
                                  No bugsplat to me, although i do not understand why some groups stay glued together..
                                  In this example there are only first-class groups:
                                    Is this plugin not compatible with the latest SU? Pilou if you've time can you look?
                                    It is behaving strangely with mixed results.
                                      dtrarch
                                      Also see Smustard for Todd Burch's ExplodeImplode script.
                                      Works OK with SU 7.1 and older.
                                      dtr
                                        [url]some groups stay glued[/url]
                                        The explosion is made by level by level of grouped elements
                                        Normally no reason for that 😄
                                        Have you a file for test it?
                                          c.plassais
                                          Hi all,
                                          just a little precision
                                          plugin Pilou ➡
                                          model = Sketchup.active_model
                                          entities = model.entities
                                          selection = model.selection
                                          xp=100  # Pivot Point (as you want)
                                          yp=100
                                          zp=100
                                          q=50 # Measure of translation (as you want)
                                          selection.each do |e| # update!
                                            # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                                            next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                                          center = e.bounds.center #Center Point of the grouped object
                                             xc= center.x
                                             yc= center.y
                                             zc= center.z
                                          xe=xc #End Point of the grouped object
                                          ye=yc
                                          ze=zc
                                          if xc<xp
                                          xe =xc - q
                                          if xc>xp
                                          xe =xc + q
                                          if yc<yp
                                          ye =yc - q
                                          if yc>yp
                                          ye =yc + q
                                          if zc<zp
                                          ze =zc - q
                                          if zc>zp
                                          ze =zc + q
                                            point = Geom;;Point3d.new xe,ye,ze
                                            t = Geom;;Transformation.new point
                                            # Apply the transformation
                                            e.transform!(t)
                                          plugin modified by me ➡
                                          # Designed December 2009 by C.plassais + Pilou
                                          # Permission to use this software for any purpose and without fee is hereby granted
                                          # Distribution of this software for commercial purpose is forbidden;
                                          # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                                          # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                                          # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                          # Name			;   Eclate_Deplace
                                          # Original Date	;  03 Juil 2009 version 0.0 (thx to TIG, Thomthom)
                                          # Type			;   Plugin
                                          # Description	;   Exploding movements of groups or/and components
                                          # Usage			;   Right Click - Context Menu
                                          # Version 0.3.2
                                          # petit plug d'explosion deplacement" de groupes ou de composants
                                          	require 'sketchup.rb'
                                          	def pilou_explose
                                          		myModel = Sketchup.active_model
                                          		myEntities = myModel.entities
                                          		selection = myModel.selection
                                          		if selection.empty?
                                          		    UI.messagebox "Veuillez Selectionner des\nComposants ou des Groupes"
                                          		myModel.start_operation "Deplacement Eclate",true
                                                  group = myModel.active_entities.add_group(selection)
                                          		centre_selec = group.bounds.center
                                          		point_ligne = UI.messagebox "Voulez-matérialiser les déplacement \npar des points et des lignes de construction", MB_YESNO
                                                  (point_ligne == 6) ? (myEntities.add_cpoint (centre_selec)) ;()
                                                  resultat1 = UI.messagebox "Voulez vous faire une copie de l'original", MB_YESNO
                                          		if resultat1 == 6
                                          		    group2 = group.copy
                                          		    group2.explode
                                                  selection = group.explode
                                                  cent_selec_x = centre_selec[0].to_i   # determination
                                          		cent_selec_y = centre_selec[1].to_i   # du centre de
                                          		cent_selec_z = centre_selec[2].to_i   # la selection
                                                 		prompts = ["Ecarter ou centrer/par rapport au pivot", "Deplacement pivot x", "Deplacement pivot y", "Deplacement pivot z", "Coef translation x de 0 a...", "Coef translation y de 0 a...", "Coef translation z de 0 a...", "Groupe Composant les 2"]
                                          		val_defaut = ["Centrer", cent_selec_x, cent_selec_y, cent_selec_z, 1.00, 1.00, 1.00, "Les 2"]
                                          		liste_val = ["Centrer|Ecarter", "", "", "", "", "", "" , "Groupe|Composant|Les 2"]
                                          		results = UI.inputbox prompts, val_defaut, liste_val, "Parametres"
                                          		return if not results
                                          		decent_pivot, deplac_pivot_x, deplac_pivot_y, deplac_pivot_z, coef_trans_x, coef_trans_y, coef_trans_z, group_ou_comp = results
                                                  # Translation des axes suivant unites
                                                  convertit = []
                                                  convertit[0]= 1.inch
                                                  convertit[1]= 1.feet
                                                  convertit[2]= 1.mm
                                                  convertit[3]= 1.cm
                                                  convertit[4]= 1.m/100
                                                  uniteCourante = myModel.options["UnitsOptions"]["LengthUnit"]
                                                  coef_trans_x = coef_trans_x.to_f * convertit[uniteCourante]
                                                  coef_trans_y = coef_trans_y.to_f * convertit[uniteCourante]
                                                  coef_trans_z = coef_trans_z.to_f * convertit[uniteCourante]
                                                  # Calcul de la distance entre le centre d'origine de la selection et le nouveau
                                                  nouv_pivot_x =  cent_selec_x-deplac_pivot_x
                                                  nouv_pivot_y =  cent_selec_y-deplac_pivot_y
                                                  nouv_pivot_z =  cent_selec_z-deplac_pivot_z
                                                  case decent_pivot
                                                       when "Ecarter"
                                                            myEntities.add_cpoint [(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]
                                                            myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]) ; ()
                                                       when "Centrer"
                                                           nouv_pivot_x =  - nouv_pivot_x
                                              		     nouv_pivot_y =  - nouv_pivot_y
                                              		     nouv_pivot_z =  - nouv_pivot_z
                                              		     myEntities.add_cpoint [deplac_pivot_x,deplac_pivot_y,deplac_pivot_z]
                                              		     myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[deplac_pivot_x, deplac_pivot_y, deplac_pivot_z]) ; ()
                                                  case group_ou_comp
                                                      when "Groupe"
                                                          group_ou_comp = comp_ou_group = Sketchup;;Group
                                                      when "Composant"
                                                          group_ou_comp = comp_ou_group = Sketchup;;ComponentInstance
                                                      else
                                          	           group_ou_comp = Sketchup;;Group
                                          		selection.each do |e| # debut de la transformation
                                          			next unless (e.is_a? group_ou_comp) or next unless(e.is_a? comp_ou_group)
                                          			centre_objet = e.bounds.center
                                          			centre_objet_x = centre_objet[0].to_i  # Determination
                                          			centre_objet_y = centre_objet[1].to_i  # du centre
                                          			centre_objet_z = centre_objet[2].to_i  # de l'objet
                                                     (centre_objet_x == cent_selec_x) ? (nouv_centobj_x = nouv_pivot_x) ; (nouv_centobj_x = ((centre_objet_x-cent_selec_x) * coef_trans_x) + nouv_pivot_x)
                                                     (centre_objet_y == cent_selec_y) ? (nouv_centobj_y = nouv_pivot_y) ; (nouv_centobj_y = ((centre_objet_y-cent_selec_y) * coef_trans_y) + nouv_pivot_y)
                                                     (centre_objet_z == cent_selec_z) ? (nouv_centobj_z = nouv_pivot_z) ; (nouv_centobj_z = ((centre_objet_z-cent_selec_z) * coef_trans_z) + nouv_pivot_z)
                                                      point_trans = Geom;;Point3d.new nouv_centobj_x,nouv_centobj_y,nouv_centobj_z
                                                      t = Geom;;Transformation.new point_trans
                                                      e.transform!(t)
                                                      nouv_centobj = e.bounds.center
                                          			myEntities.add_cpoint (nouv_centobj)
                                          			myEntities.add_cpoint (centre_objet)
                                          			constline = myEntities.add_cline [centre_objet_x, centre_objet_y, centre_objet_z],nouv_centobj
                                          			constline.stipple = ".") ; ()
                                          			myModel.selection.add e
                                          		myModel.commit_operation
                                          	end # pilou_explose
                                          	if( not file_loaded?("Eclate_Deplace.rb") )
                                                  UI.add_context_menu_handler do |context_menu|
                                          	       context_menu.add_separator
                                          	       context_menu.add_item("Eclate_Deplace") { pilou_explose }
                                                  file_loaded("Eclate_Deplace.rb")
                                          Christophe
                                            No problem 😄
                                            Idea 💭 Pilou for training Ruby 5%
                                            Realisation Ruby C.Plassais 95%
                                            • 8
                                            • 9
                                            • 2 / 9
