    Render this: SSS
    174 Posts 44 Posters 31.3k Views 44 Watching
    • soloS Offline
      solo
      Nice one Adam.
      http://www.solos-art.com
      • EarthMoverE Offline
        EarthMover
        Thanks Pete...I actually cheated a little and used the high poly dragon since it was in Max. Looking at yours...I should've jacked up the specularity a little.
        Pete, have you tried using different color lights with a white SSS material? That should be interesting.
        Content Creator at Skapeup
        • soloS Offline
          solo
          a quick 30 second render.
          • soloS Offline
            solo
            Four lights, two red, two white.
            I used a bump map.
              EarthMover
              Wow Pete..the last one is amazing. The bump map really made it pop.
                avariant
                Red rubber ball
                  remus
                  Blue rubber material again.
                  • soloS Offline
                    solo
                    Remus, that's a very convincing looking rubber mat.
                    • soloS Offline
                      solo
                      This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
                      • jeff hammondJ Offline
                        jeff hammond
                        ha, i was going for a blue rubber dragon too.. 😄
                        was going to let it cook longer but stopped it after seeing remus'..
                        http://homepage.mac.com/jeffhammond/.Public/scf/dragon.jpg
                        dotdotdot
                          EarthMover
                          WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
                            remus
                            just downloaded the material form the indigo materials database, so cant take any credit for it 😉
                              Twilight User
                              Here's my problem -
                              Place model in 'Basic Studio' with Omni Light behind model
                              Apply SSS material to model (Red Gum)
                              Sunlight Disabled
                              Sky Type - Background Color (Black)
                              Render at Medium+ (Still Cooking after 30mins)
                              Vista64bit - AMD Turion X2 Dual Core - 4GB
                              When i cooked at lower presets the model was very dark? Do i need to up light size?
                                EarthMover
                                Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
                                And another without the skin bitmap.
                                • soloS Offline
                                  solo
                                  Rich
                                  So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
                                  I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
                                  However, try adding another point light behind camera also
                                    Chris_at_Twilight
                                    Twilight User
                                    Here's my problem -
                                    Sunlight Disabled
                                    The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
                                    http://www.TwilightRender.com
                                      avariant
                                      Twilight User
                                      Here's my problem - ...
                                      The red rubber dragon I posted above was done in Twilight. I just used the SSS Rubber Ball right out of the box. It's done with Interior +, so that's probably the difference.
                                      This is Twilight also.
                                        EarthMover
                                        Avariant..iridescent one is fantastic. Really good showing from Twilight.
                                        Last one from me. Added some displacement in the mix.
                                        • E Offline
                                          Ecuadorian
                                          I just want to print and hang in my walls all renders by Remus, Pete and Adam, they're wonderful!
                                          -Miguel Lescano
                                          • olisheaO Offline
                                            olishea
                                            earthmover these are fantastic! and yeah remus that blue rubber is amazing!
                                            oli
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
