    Render this: SSS
    174 Posts 44 Posters 45.5k Views 44 Watching
    • soloS Offline
      This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
      • jeff hammondJ Offline
        ha, i was going for a blue rubber dragon too.. 😄
        was going to let it cook longer but stopped it after seeing remus'..
        http://homepage.mac.com/jeffhammond/.Public/scf/dragon.jpg
        • EarthMoverE Offline
          EarthMover
          WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
          Content Creator at Skapeup
            remus
            just downloaded the material form the indigo materials database, so cant take any credit for it 😉
              Twilight User
              Here's my problem -
              Place model in 'Basic Studio' with Omni Light behind model
              Apply SSS material to model (Red Gum)
              Sunlight Disabled
              Sky Type - Background Color (Black)
              Render at Medium+ (Still Cooking after 30mins)
              Vista64bit - AMD Turion X2 Dual Core - 4GB
              When i cooked at lower presets the model was very dark? Do i need to up light size?
                EarthMover
                Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
                And another without the skin bitmap.
                • soloS Offline
                  Rich
                  So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
                  I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
                  However, try adding another point light behind camera also
                    Chris_at_Twilight
                    Twilight User
                    Here's my problem -
                    Sunlight Disabled
                    The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
                    http://www.TwilightRender.com
                      avariant
                      Twilight User
                      Here's my problem - ...
                      The red rubber dragon I posted above was done in Twilight. I just used the SSS Rubber Ball right out of the box. It's done with Interior +, so that's probably the difference.
                      This is Twilight also.
                        EarthMover
                        Avariant..iridescent one is fantastic. Really good showing from Twilight.
                        Last one from me. Added some displacement in the mix.
                        • E Offline
                          Ecuadorian
                          I just want to print and hang in my walls all renders by Remus, Pete and Adam, they're wonderful!
                          -Miguel Lescano
                          • olisheaO Offline
                            olishea
                            earthmover these are fantastic! and yeah remus that blue rubber is amazing!
                            oli
                            • daleD Offline
                              dale
                              A little from Kerkythea
                              • soloS Offline
                                My first twilight attempt.
                                • E Offline
                                  Ecuadorian
                                  A couple of lazy attempts with just Twilight library materials:
                                  Milk:
                                  And blue gum. Indigo and Maxwell beat Twilight big time when it comes to blue gum/rubber. 😞
                                  -Miguel Lescano
                                    I'm sick as a parrot after that one.
                                    What the $@#* am I doing wrong?
                                    I've read the manual, I've followed the tuts. All that's left is to remove the mallet from my ass and beat myself with it
                                    Goodnight
                                    • soloS Offline
                                      Rich, here is my setup, see I have 3 lights behind and one in front, I rendered using preset #9
                                      I used the studio setup, painted black, I have no sun and a black background.
                                        Click Draw
                                        Here's my attempt....
                                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                          Click Draw
                                          looks like I'm a bit behind.....oops 😳 Guess I've been Dragon my ass.... 🤣
                                            d12dozr
                                            Fantastic renders, guys! This is so cool 😎
                                            Using Twilight, I also had the same problem as Rich, I started using the Low and Medium presets and it was taking forever, but I'm getting much better results after switching to #10 - Interior+ (but not good enough to post here yet)
                                            http://goo.gl/f7ooYh
                                            • 4 / 9
