    Render this: SSS
    174 Posts 44 Posters 45.5k Views 44 Watching
    • soloS Offline
      Four lights, two red, two white.
      I used a bump map.
      • EarthMoverE Offline
        EarthMover
        Wow Pete..the last one is amazing. The bump map really made it pop.
        Content Creator at Skapeup
          avariant
          Red rubber ball
            remus
            Blue rubber material again.
            • soloS Offline
              Remus, that's a very convincing looking rubber mat.
              • soloS Offline
                This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
                • jeff hammondJ Offline
                  ha, i was going for a blue rubber dragon too.. 😄
                  was going to let it cook longer but stopped it after seeing remus'..
                  http://homepage.mac.com/jeffhammond/.Public/scf/dragon.jpg
                    EarthMover
                    WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
                      remus
                      just downloaded the material form the indigo materials database, so cant take any credit for it 😉
                        Twilight User
                        Here's my problem -
                        Place model in 'Basic Studio' with Omni Light behind model
                        Apply SSS material to model (Red Gum)
                        Sunlight Disabled
                        Sky Type - Background Color (Black)
                        Render at Medium+ (Still Cooking after 30mins)
                        Vista64bit - AMD Turion X2 Dual Core - 4GB
                        When i cooked at lower presets the model was very dark? Do i need to up light size?
                          EarthMover
                          Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
                          And another without the skin bitmap.
                          • soloS Offline
                            Rich
                            So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
                            I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
                            However, try adding another point light behind camera also
                              Chris_at_Twilight
                              Twilight User
                              Here's my problem -
                              Sunlight Disabled
                              The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
                              http://www.TwilightRender.com
                                avariant
                                Twilight User
                                Here's my problem - ...
                                The red rubber dragon I posted above was done in Twilight. I just used the SSS Rubber Ball right out of the box. It's done with Interior +, so that's probably the difference.
                                This is Twilight also.
                                  EarthMover
                                  Avariant..iridescent one is fantastic. Really good showing from Twilight.
                                  Last one from me. Added some displacement in the mix.
                                  • E Offline
                                    Ecuadorian
                                    I just want to print and hang in my walls all renders by Remus, Pete and Adam, they're wonderful!
                                    -Miguel Lescano
                                    • olisheaO Offline
                                      olishea
                                      earthmover these are fantastic! and yeah remus that blue rubber is amazing!
                                      oli
                                      • daleD Offline
                                        dale
                                        A little from Kerkythea
                                        • soloS Offline
                                          My first twilight attempt.
                                          • E Offline
                                            Ecuadorian
                                            A couple of lazy attempts with just Twilight library materials:
                                            Milk:
                                            And blue gum. Indigo and Maxwell beat Twilight big time when it comes to blue gum/rubber. 😞
                                            -Miguel Lescano
                                            • 4 / 9
