    Render this: SSS
    174 Posts 44 Posters 47.6k Views 44 Watching
    • EarthMoverE
      EarthMover
      WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
      Content Creator at Skapeup
        remus
        just downloaded the material form the indigo materials database, so cant take any credit for it 😉
          Twilight User
          Here's my problem -
          Place model in 'Basic Studio' with Omni Light behind model
          Apply SSS material to model (Red Gum)
          Sunlight Disabled
          Sky Type - Background Color (Black)
          Render at Medium+ (Still Cooking after 30mins)
          Vista64bit - AMD Turion X2 Dual Core - 4GB
          When i cooked at lower presets the model was very dark? Do i need to up light size?
          • EarthMoverE
            EarthMover
            Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
            And another without the skin bitmap.
            • soloS
              Rich
              So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
              I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
              However, try adding another point light behind camera also
              • C
                Chris_at_Twilight
                Twilight User
                Here's my problem -
                Sunlight Disabled
                The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
                http://www.TwilightRender.com
                  avariant
                  Twilight User
                  Here's my problem - ...
                  The red rubber dragon I posted above was done in Twilight. I just used the SSS Rubber Ball right out of the box. It's done with Interior +, so that's probably the difference.
                  This is Twilight also.
                  • EarthMoverE
                    EarthMover
                    Avariant..iridescent one is fantastic. Really good showing from Twilight.
                    Last one from me. Added some displacement in the mix.
                    • E
                      Ecuadorian
                      I just want to print and hang in my walls all renders by Remus, Pete and Adam, they're wonderful!
                      -Miguel Lescano
                      • olisheaO
                        olishea
                        earthmover these are fantastic! and yeah remus that blue rubber is amazing!
                        oli
                        • daleD
                          dale
                          A little from Kerkythea
                          • soloS
                            My first twilight attempt.
                            • E
                              Ecuadorian
                              A couple of lazy attempts with just Twilight library materials:
                              Milk:
                              And blue gum. Indigo and Maxwell beat Twilight big time when it comes to blue gum/rubber. 😞
                              -Miguel Lescano
                                I'm sick as a parrot after that one.
                                What the $@#* am I doing wrong?
                                I've read the manual, I've followed the tuts. All that's left is to remove the mallet from my ass and beat myself with it
                                Goodnight
                                • soloS
                                  Rich, here is my setup, see I have 3 lights behind and one in front, I rendered using preset #9
                                  I used the studio setup, painted black, I have no sun and a black background.
                                  • C
                                    Click Draw
                                    Here's my attempt....
                                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                    • C
                                      Click Draw
                                      looks like I'm a bit behind.....oops 😳 Guess I've been Dragon my ass.... 🤣
                                        d12dozr
                                        Fantastic renders, guys! This is so cool 😎
                                        Using Twilight, I also had the same problem as Rich, I started using the Low and Medium presets and it was taking forever, but I'm getting much better results after switching to #10 - Interior+ (but not good enough to post here yet)
                                        http://goo.gl/f7ooYh
                                        • W
                                          woodtick
                                          Very interesting thread........thanks for starting this.I've just started working with Twilight and rendering in general.Keep in mind I'm a carpenter, not a graphic artist so any breach of rendering etiquette is purely unintentional. This is what I came up with....not sure it meets any of the sss criteria but it sure was fun trying.
                                          Rich
                                          • E
                                            Ecuadorian
                                            Twilight Render's Easy 09 preset should be enough; Easy 10 enables color dispersion and some other special FX, however.
                                            I made two more tries: One with Easy 09 and another one with Easy 10. I stacked them together:
                                            And then added some airbrush to the eyes and altered the curves a little bit in GIMP:
                                            Hey, Pete, how about "Emitters and LEMs" for the next "Render this"?
                                            -Miguel Lescano
                                            • 4 / 9
