    Render this: SSS
    174 Posts 44 Posters 47.6k Views 44 Watching
    • dermotcollD
      dermotcoll
      This is my last attempt at this - The SSS material in the twilght library didnt render well at all as the cube material turned out very flat. This one came out very interesting with the HDRi image really affecting it. I'm learning alot using this tutorial
      When you burn your arse - you gotta sit on the blisters!!
      • E
        Ecuadorian
        After doing some more research on the subject now I think some of the renders here show more absorption than SSS. The classic example of an SSS material is human skin.
        Thanks for the dragon, Pete, I'll give it a go tonight.
        -Miguel Lescano
          remus
          Cheers for the standford dragon model solo, ive tried getting it in to SU a few times but its always been to heavy. I guess you poly reduced it a lot before taking it in to SU?
          • soloS
            Pleasure guys, yeah Remus I reduced it 90%, so lots of fine detail is lost.
            Miguel, SSS has many factors, human skin is an example of the Translucency of a material as well as forward absorbsion. Jade will have less translucency, more refraction and slight absorbtion.
            Here is my attempt at Ruby material, as well as my settings.
            • soloS
              Nice one Adam.
              • EarthMoverE
                EarthMover
                Thanks Pete...I actually cheated a little and used the high poly dragon since it was in Max. Looking at yours...I should've jacked up the specularity a little.
                Pete, have you tried using different color lights with a white SSS material? That should be interesting.
                Content Creator at Skapeup
                • soloS
                  a quick 30 second render.
                  • soloS
                    Four lights, two red, two white.
                    I used a bump map.
                    • EarthMoverE
                      EarthMover
                      Wow Pete..the last one is amazing. The bump map really made it pop.
                        avariant
                        Red rubber ball
                          remus
                          Blue rubber material again.
                          • soloS
                            Remus, that's a very convincing looking rubber mat.
                            • soloS
                              This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
                              • jeff hammondJ
                                ha, i was going for a blue rubber dragon too.. 😄
                                was going to let it cook longer but stopped it after seeing remus'..
                                http://homepage.mac.com/jeffhammond/.Public/scf/dragon.jpg
                                • EarthMoverE
                                  EarthMover
                                  WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
                                    remus
                                    just downloaded the material form the indigo materials database, so cant take any credit for it 😉
                                      Twilight User
                                      Here's my problem -
                                      Place model in 'Basic Studio' with Omni Light behind model
                                      Apply SSS material to model (Red Gum)
                                      Sunlight Disabled
                                      Sky Type - Background Color (Black)
                                      Render at Medium+ (Still Cooking after 30mins)
                                      Vista64bit - AMD Turion X2 Dual Core - 4GB
                                      When i cooked at lower presets the model was very dark? Do i need to up light size?
                                      • EarthMoverE
                                        EarthMover
                                        Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
                                        And another without the skin bitmap.
                                        • soloS
                                          Rich
                                          So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
                                          I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
                                          However, try adding another point light behind camera also
                                          • C
                                            Chris_at_Twilight
                                            Twilight User
                                            Here's my problem -
                                            Sunlight Disabled
                                            The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
                                            http://www.TwilightRender.com
                                            • 4 / 9
