    Render this: SSS
    174 Posts 44 Posters 47.6k Views 44 Watching
    • soloS
      I did a quick one using the studio setup from the other thread and three lights.
      • daleD
        dale
        Before I put myself into the mouth of the dragon I will post these
          7homuz
          now you just need a jade sss material
          • daleD
            dale
            and one more
            • olisheaO
              olishea
              nice pete, looks real! good thread mate, dont get to use sss at all really.
              oli
              • dermotcollD
                dermotcoll
                This is my last attempt at this - The SSS material in the twilght library didnt render well at all as the cube material turned out very flat. This one came out very interesting with the HDRi image really affecting it. I'm learning alot using this tutorial
                When you burn your arse - you gotta sit on the blisters!!
                • E
                  Ecuadorian
                  After doing some more research on the subject now I think some of the renders here show more absorption than SSS. The classic example of an SSS material is human skin.
                  Thanks for the dragon, Pete, I'll give it a go tonight.
                  -Miguel Lescano
                    remus
                    Cheers for the standford dragon model solo, ive tried getting it in to SU a few times but its always been to heavy. I guess you poly reduced it a lot before taking it in to SU?
                    • soloS
                      Pleasure guys, yeah Remus I reduced it 90%, so lots of fine detail is lost.
                      Miguel, SSS has many factors, human skin is an example of the Translucency of a material as well as forward absorbsion. Jade will have less translucency, more refraction and slight absorbtion.
                      Here is my attempt at Ruby material, as well as my settings.
                      • soloS
                        Nice one Adam.
                        • EarthMoverE
                          EarthMover
                          Thanks Pete...I actually cheated a little and used the high poly dragon since it was in Max. Looking at yours...I should've jacked up the specularity a little.
                          Pete, have you tried using different color lights with a white SSS material? That should be interesting.
                          Content Creator at Skapeup
                          • soloS
                            a quick 30 second render.
                            • soloS
                              Four lights, two red, two white.
                              I used a bump map.
                              • EarthMoverE
                                EarthMover
                                Wow Pete..the last one is amazing. The bump map really made it pop.
                                  avariant
                                  Red rubber ball
                                    remus
                                    Blue rubber material again.
                                    • soloS
                                      Remus, that's a very convincing looking rubber mat.
                                      • soloS
                                        This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
                                        • jeff hammondJ
                                          ha, i was going for a blue rubber dragon too.. 😄
                                          was going to let it cook longer but stopped it after seeing remus'..
                                          http://homepage.mac.com/jeffhammond/.Public/scf/dragon.jpg
                                          • EarthMoverE
                                            EarthMover
                                            WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
                                            • 4 / 9
