    [Plugin] Flatten and Extrude
    46 Posts 11 Posters 44.7k Views 11 Watching
    • thomthomT
      Overview
      I often get tasks to model terrain and context buildings for project we do. It's dog boring work!
      Today when I got a new such project with a large plan I thought there had to be a better way to do most of this repetitive work. So I wrote a crude script to lessen some of my burden.
      The purpose of this script was just to get the bulk work done. Don't expect any magic from it.
      Note: Result will vary from the quality of the lines you feed it. I've just mocked this up to get a job done - so the UI is crude. I want to get back to this later and provide a better interface. But until them; this is it.
      Menus: Plugins->Flatten->...
      Functions
      Flatten
      (Only takes a single group or component as input at the moment, sorry.)
      Creates a new group where all the edges in the selected Group or Component is projected down to the Ground (Elevation 0).
      Flatten and Extrude
      Same as flatten, but it then tries to extrude the faces back up to the lowest/highest point above it.
      Note that there is a layer filter where the plugin will only use the edges on layers containing that filter. The filter is a series of strings separated by | (pipe character).
      (Yes, I know. The settings isn't persistent. Will see if I can get around for a quick update for that later. Until then - modify line 120 yourself.)
      Smart People!
      Does anyone have any idea of how to generate roofs? Not generic roofs, but ones that fit the roof edges.
      404 Not Found
      (sketchucation.com)
      • R
        remus
        For the roofs, perhaps have a look at TIGs roof script. I imagine itd be fairly easy to filter all the horizontal faces that have some z then apply TIGs roof stuff to it with some generic/random values plugged in (depending on what sort of results your after.)
        • thomthomT
          πŸ˜‰
          Making generic roofs is the current work around. But being able to produce roofs from the CAD lines would be really cool. I don't expect perfect roofs, but at least some approximation.
          One possible alternative would be to get the height of the roof from the CAD lines and make a generic roof from that...
          • R
            remus
            • thomthomT
              No worries! πŸ˜„ πŸ˜‰
              • D
                dtrarch
                TT
                How about using TIG's Height/datum tool to set Z with your new tool.
                Hmmm?
                dtr
                • thomthomT
                  @dtrarch said:
                  TT
                  Hmmm?
                  dtr
                  Set Z? What you mean?
                  • TIGT
                    My Datum tool sets a 'Z' datum in your model [as an attribute] so when z=0 z_datum=123.456m or whatever. Then you use the tool to add text to refer to a point so that floors or points on an elevation etc are given their corrected height above 'datum', rather than z=0...
                    • thomthomT
                      Ok - but how does that relate to this plugin? (I'm confused...)
                      • TIGT
                        I surmise he means instead of flattening everything to z-o allow you to set it to flatten to z=123.456m. Easy done as it's in a group - flatten all to z=0 end with an option to enter a new z or pick a point and move the flattened group up/down to suit the desired z ???
                        • thomthomT
                          That would move the top above the lines it extrudes up to. But it's just as easy to just to flatten down to a given Z level.
                          Anyway - thanks for clearing that up. Will see if I'll be adding that in the future.
                          Btw, does your Z-Level plugin expose the Z Height publicly? Wondering if I can read the value and use that as default if present.
                          • TIGT
                            Frankly I'd keep them separate...
                              Flat land πŸ˜‰
                              • thomthomT
                                Flat land πŸ˜‰
                                Someone's been snooping in the code, eh? πŸ˜„ It just so happened to be the last book I read. πŸ€“
                                • K
                                  kwistenbiebel
                                  Nice idea thomthom. Things are busy now, but I will try the plugin in depth at the weekend.
                                  For architects this is extremely useful!
                                  Now I don't have to ask the Rhino guy to do it for me and to import it in SU πŸ˜‰
                                  By the way,
                                  I love the CookieWare idea! Whenever you're in Australia, please drop by for a beer... πŸ˜„
                                  • D
                                    dtrarch
                                    I yield πŸ‘Š
                                    Just thought that muli-level flat and extrude might be a possible for structural elements and such.
                                    tt many thanks in any case β˜€
                                    dtr
                                    • utilerU
                                      utiler
                                      By the way,
                                      Some nice boutique breweries over there, kwist......
                                      After you've had a few beers with kwist, Thom fly across the other side of the country and I'll shout you a few also!!! πŸ‘
                                      Just Curious...
                                      • thomthomT
                                        Rhino has a function like this??
                                        • thomthomT
                                          @dtrarch said:
                                          I yield πŸ‘Š
                                          dtr
                                          Multi-level flat and extrude? Could you care to explain more what you got in mind?
                                          • G
                                            gavvy
                                            πŸ˜’
                                            I tride this plugin .The groups in the group can't be faltten
                                            Is it a better idea to flatten the group in group,and hold the group of faces?
                                            to build a city ,i always use clf_greeble_2.rb πŸ˜„
                                            • 1 / 3
