    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      tomot
      @thomthom said:
      Have you looked at TIGs tools?
      I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
      TIG solid solver
      TT cleanup
      Fix solid
      ky delete Interior faces
      wikii remove Inner Faces
      none of them perform interior face removal 😞
      my plugins
      tomot
        tomot
        @mitcorb said:
        Remove Inner Faces by wikii in the Plugins Index.
        Thanks! it was the first one I tried a while ago, it also did not meet the test.
        I added to my list, in the event someone else is searching this subject.
        my plugins
        tomot
        • mitcorbM Offline
          mitcorb
          Actually, olishea said it first. I was just clarifying who what the when where and how.
            tomot
            @thomthom said:
            "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
            NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
            my plugins
            tomot
            • david_hD Offline
              david_h
              I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
              • P Offline
                penumbra
                try here;
                http://sketchucation.com/forums/viewtopic.php?t=30503
                  Linked right above the download link - under the "Requirements" header.
                    Seems there is not an inner faces selection eraser?
                    • david_hD Offline
                      david_h
                      Thanks. I have that and I have run the little installer as well.
                      It's going now. thank you.
                      You see. . this is why I really shouldn't be wearing the green badge.
                        shifo1002000
                        I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                        no such file to load -- TT_Lib2/core.rb)
                        Can you please help?
                        I also posted on your video on YouTube, sorry for the inconvenience
                        • massimoM Offline
                          massimo Moderator
                          Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
                            shifo1002000
                            I followed your instructions and it worked 😄 thanks a million
                              I'll repackage the plugin as an RBZ and better message for missing TT_Lib2.
                              • P Offline
                                Piratestef
                                with what settings should I clean up this file?
                                https://www.dropbox.com/s/vpqng31chal8v4l/brad%20kussens.skp
                                It keeps losing surfaces, could you work your magic and tell me what settings to use?
                                I really hope this works!
                                  I'm out traveling so I cannot open the file right now. But I'll guess that the missing faces are very small. When edges are less near and less than 1mm things like that start happening. You'd then have to scale up the model.
                                  Note that scaling the instance won't work. You'd have to open up the group or component.
                                  Sent from my LT25i using Tapatalk 2
                                  • P Offline
                                    Piratestef
                                    Ok so I scaled it with 200%, with what setting should I start the cleanup?
                                      I don't know what settings to recommend because I do not know what result you expect. All the settings are for different proposes.
                                      Btw, 2 times might not be enough scaling. You might have to scale up by 10, 100 or 1000 times.
                                        rs3sekar
                                        Thanks a lot - very useful tool
                                        • E Offline
                                          ephraimlord65
                                          Really cool ! Nice job and thanks a lot for this plugin ! 😉
                                            Mybis
                                            Please disregard my question below. The std RBZ installer in my SU8 doesn't seem to work so having read some of your related info I simply changed the RBZ's to ZIP, unpacked them, and moved them to the plug in folder. PU's seem to work fine. Looking fwd to using your cleanup PI ... sounds awesome.
                                            Tks.
                                            Hi, I'm new to the plug in concept in SU so my apologies in advance.
                                            Im on Mac OS10.8.3 / SUpro V8.
                                            I am keen to install your cleanup PI and I keep getting the following error
                                            "SketchUp was unable to install the Extension you have chosen for some unknown reason.
                                            Consult your Extension's documentation for additional help"
                                            It seems to come up regardless of the rbz file that I am trying to install.
                                            Any advise will be greatly appreciated!
                                            scott
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
