[Plugin] CleanUp
You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
Yes I included that thread also, visually I did not find anything.
Use the browser's search feature to quickly find things. (Often F3 activates it)
Remove Inner Faces by wikii in the Plugins Index.
@thomthom said:
Have you looked at TIGs tools?
I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
TIG solid solver
TT cleanup
Fix solid
ky delete Interior faces
wikii remove Inner Faces
none of them perform interior face removal
Thanks! it was the first one I tried a while ago, it also did not meet the test.
I added to my list, in the event someone else is searching this subject. -
Actually, olishea said it first. I was just clarifying who what the when where and how.
@thomthom said:
"unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
try here;
Linked right above the download link - under the "Requirements" header.
Seems there is not an inner faces selection eraser?
Thanks. I have that and I have run the little installer as well.
It's going now. thank you.
You see. . this is why I really shouldn't be wearing the green badge.
I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
no such file to load -- TT_Lib2/core.rb)
Can you please help?
I also posted on your video on YouTube, sorry for the inconvenience -
Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
I followed your instructions and it worked
thanks a million -
I'll repackage the plugin as an RBZ and better message for missing TT_Lib2.
with what settings should I clean up this file?
https://www.dropbox.com/s/vpqng31chal8v4l/brad%20kussens.skp
It keeps losing surfaces, could you work your magic and tell me what settings to use?
I really hope this works! -
I'm out traveling so I cannot open the file right now. But I'll guess that the missing faces are very small. When edges are less near and less than 1mm things like that start happening. You'd then have to scale up the model.
Note that scaling the instance won't work. You'd have to open up the group or component.Sent from my LT25i using Tapatalk 2
