    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • T
      tomot
      @olishea said:
      Have you tried Remove Inner Faces plugin?!
      Where? there is no such name when searching at this forum or at the ruby library depot.๐Ÿ˜ž
      my plugins
      tomot
        You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
        • voljankoV
          voljanko
          @tomot said:
          OK!..... please attach my file with you 1 button fix ๐Ÿ‘
          No problem ๐Ÿ˜„
          Hilbert_all_solids.skp
          SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
          • T
            tomot
            Yes I included that thread also, visually I did not find anything. ๐Ÿ˜ž
            my plugins
            tomot
              Use the browser's search feature to quickly find things. (Often F3 activates it)
              • mitcorbM
                mitcorb
                Remove Inner Faces by wikii in the Plugins Index.
                • T
                  tomot
                  @thomthom said:
                  Have you looked at TIGs tools?
                  I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
                  TIG solid solver
                  TT cleanup
                  Fix solid
                  ky delete Interior faces
                  wikii remove Inner Faces
                  none of them perform interior face removal ๐Ÿ˜ž
                  my plugins
                  tomot
                  • T
                    tomot
                    Thanks! it was the first one I tried a while ago, it also did not meet the test.
                    I added to my list, in the event someone else is searching this subject.
                    my plugins
                    tomot
                    • mitcorbM
                      mitcorb
                      Actually, olishea said it first. I was just clarifying who what the when where and how.
                      • T
                        tomot
                        @thomthom said:
                        "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                        NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
                        my plugins
                        tomot
                        • david_hD
                          david_h
                          I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
                          • P
                            penumbra
                            try here;
                            404 Not Found
                            (sketchucation.com)
                              Linked right above the download link - under the "Requirements" header.
                                Seems there is not an inner faces selection eraser?
                                • david_hD
                                  david_h
                                  Thanks. I have that and I have run the little installer as well.
                                  It's going now. thank you.
                                  You see. . this is why I really shouldn't be wearing the green badge.
                                    shifo1002000
                                    I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                                    no such file to load -- TT_Lib2/core.rb)
                                    Can you please help?
                                    I also posted on your video on YouTube, sorry for the inconvenience
                                    • massimoM
                                      massimo Moderator
                                      Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
                                        shifo1002000
                                        I followed your instructions and it worked ๐Ÿ˜„ thanks a million
                                          I'll repackage the plugin as an RBZ and better message for missing TT_Lib2.
                                          • P
                                            Piratestef
                                            with what settings should I clean up this file?
                                            https://www.dropbox.com/s/vpqng31chal8v4l/brad%20kussens.skp
                                            It keeps losing surfaces, could you work your magic and tell me what settings to use?
                                            I really hope this works!
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
