    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • T
      tomot
      @mitcorb said:
      Remove Inner Faces by wikii in the Plugins Index.
      Thanks! it was the first one I tried a while ago, it also did not meet the test.
      I added to my list, in the event someone else is searching this subject.
      my plugins
      tomot
      • mitcorbM
        mitcorb
        Actually, olishea said it first. I was just clarifying who what the when where and how.
        • T
          tomot
          @thomthom said:
          "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
          NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
          my plugins
          tomot
          • david_hD
            david_h
            I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
            • P
              penumbra
              try here;
              404 Not Found
              (sketchucation.com)
                Linked right above the download link - under the "Requirements" header.
                  Seems there is not an inner faces selection eraser?
                  • david_hD
                    david_h
                    Thanks. I have that and I have run the little installer as well.
                    It's going now. thank you.
                    You see. . this is why I really shouldn't be wearing the green badge.
                      shifo1002000
                      I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                      no such file to load -- TT_Lib2/core.rb)
                      Can you please help?
                      I also posted on your video on YouTube, sorry for the inconvenience
                      • massimoM
                        massimo Moderator
                        Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
                          shifo1002000
                          I followed your instructions and it worked 😄 thanks a million
                            I'll repackage the plugin as an RBZ and better message for missing TT_Lib2.
                            • P
                              Piratestef
                              with what settings should I clean up this file?
                              https://www.dropbox.com/s/vpqng31chal8v4l/brad%20kussens.skp
                              It keeps losing surfaces, could you work your magic and tell me what settings to use?
                              I really hope this works!
                                I'm out traveling so I cannot open the file right now. But I'll guess that the missing faces are very small. When edges are less near and less than 1mm things like that start happening. You'd then have to scale up the model.
                                Note that scaling the instance won't work. You'd have to open up the group or component.
                                Sent from my LT25i using Tapatalk 2
                                • P
                                  Piratestef
                                  Ok so I scaled it with 200%, with what setting should I start the cleanup?
                                    I don't know what settings to recommend because I do not know what result you expect. All the settings are for different proposes.
                                    Btw, 2 times might not be enough scaling. You might have to scale up by 10, 100 or 1000 times.
                                      rs3sekar
                                      Thanks a lot - very useful tool
                                      • E
                                        ephraimlord65
                                        Really cool ! Nice job and thanks a lot for this plugin ! 😉
                                          Mybis
                                          Please disregard my question below. The std RBZ installer in my SU8 doesn't seem to work so having read some of your related info I simply changed the RBZ's to ZIP, unpacked them, and moved them to the plug in folder. PU's seem to work fine. Looking fwd to using your cleanup PI ... sounds awesome.
                                          Tks.
                                          Hi, I'm new to the plug in concept in SU so my apologies in advance.
                                          Im on Mac OS10.8.3 / SUpro V8.
                                          I am keen to install your cleanup PI and I keep getting the following error
                                          "SketchUp was unable to install the Extension you have chosen for some unknown reason.
                                          Consult your Extension's documentation for additional help"
                                          It seems to come up regardless of the rbz file that I am trying to install.
                                          Any advise will be greatly appreciated!
                                          scott
                                            That sounds like a issue that appear from time to time - where OSX users for some reason didn't have full access to the Plugins folder. Once they gave them selves full access they where able to use the RBZ installation feature.
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
