    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
    • olisheaO
      olishea
      @tomot said:
      none of them perform interior face removal ๐Ÿ˜ž
      Have you tried Remove Inner Faces plugin?!
      oli
      • T
        tomot
        @voljanko said:
        Hello,
        I have checked the model it with SuSolid plugin and fixed the model with 1 button.
        David
        OK!..... please attach my file with you 1 button fix ๐Ÿ‘
        my plugins
        tomot
        • T
          tomot
          Where? there is no such name when searching at this forum or at the ruby library depot.๐Ÿ˜ž
          my plugins
          tomot
            You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
            • voljankoV
              voljanko
              No problem ๐Ÿ˜„
              Hilbert_all_solids.skp
              SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
              • T
                tomot
                Yes I included that thread also, visually I did not find anything. ๐Ÿ˜ž
                my plugins
                tomot
                  Use the browser's search feature to quickly find things. (Often F3 activates it)
                  • mitcorbM
                    mitcorb
                    Remove Inner Faces by wikii in the Plugins Index.
                    • T
                      tomot
                      @thomthom said:
                      Have you looked at TIGs tools?
                      I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
                      TIG solid solver
                      TT cleanup
                      Fix solid
                      ky delete Interior faces
                      wikii remove Inner Faces
                      my plugins
                      tomot
                      • T
                        tomot
                        Thanks! it was the first one I tried a while ago, it also did not meet the test.
                        I added to my list, in the event someone else is searching this subject.
                        my plugins
                        tomot
                        • mitcorbM
                          mitcorb
                          Actually, olishea said it first. I was just clarifying who what the when where and how.
                          • T
                            tomot
                            @thomthom said:
                            "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                            NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
                            my plugins
                            tomot
                            • david_hD
                              david_h
                              I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
                              • P
                                penumbra
                                try here;
                                404 Not Found
                                (sketchucation.com)
                                  Linked right above the download link - under the "Requirements" header.
                                    Seems there is not an inner faces selection eraser?
                                    • david_hD
                                      david_h
                                      Thanks. I have that and I have run the little installer as well.
                                      It's going now. thank you.
                                      You see. . this is why I really shouldn't be wearing the green badge.
                                        shifo1002000
                                        I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                                        no such file to load -- TT_Lib2/core.rb)
                                        Can you please help?
                                        I also posted on your video on YouTube, sorry for the inconvenience
                                        • massimoM
                                          massimo Moderator
                                          Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
                                            shifo1002000
                                            I followed your instructions and it worked ๐Ÿ˜„ thanks a million
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
