    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
    • voljankoV
      voljanko
      @tomot said:
      I created a simple cube greeble ruby a while ago that draws an array of cubes in xy, xz, yz, or xyz planes. My idea was to carve out cubes from these arrays to create other 3d objects, retaining the basic cube module, much like the Voxel idea. Attached is 3d object file.
      I ran Cleanup on this file. but it was unable to delete the redundant interior faces.
      In addition is Cleanup able to remove the unnecessary exterior cube lines while retaining the integrity of the 3d object?
      Hello,
      I have checked the model it with SuSolid plugin and fixed the model with 1 button.
      David
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
      • olisheaO
        olishea
        @tomot said:
        none of them perform interior face removal ๐Ÿ˜ž
        Have you tried Remove Inner Faces plugin?!
        oli
        • T
          tomot
          @voljanko said:
          Hello,
          David
          OK!..... please attach my file with you 1 button fix ๐Ÿ‘
          my plugins
          tomot
          • T
            tomot
            Where? there is no such name when searching at this forum or at the ruby library depot.๐Ÿ˜ž
            my plugins
            tomot
              You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
              • voljankoV
                voljanko
                No problem ๐Ÿ˜„
                Hilbert_all_solids.skp
                • T
                  tomot
                  Yes I included that thread also, visually I did not find anything. ๐Ÿ˜ž
                  my plugins
                  tomot
                    Use the browser's search feature to quickly find things. (Often F3 activates it)
                    • mitcorbM
                      mitcorb
                      Remove Inner Faces by wikii in the Plugins Index.
                      • T
                        tomot
                        @thomthom said:
                        Have you looked at TIGs tools?
                        I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
                        TIG solid solver
                        TT cleanup
                        Fix solid
                        ky delete Interior faces
                        wikii remove Inner Faces
                        my plugins
                        tomot
                        • T
                          tomot
                          Thanks! it was the first one I tried a while ago, it also did not meet the test.
                          I added to my list, in the event someone else is searching this subject.
                          my plugins
                          tomot
                          • mitcorbM
                            mitcorb
                            Actually, olishea said it first. I was just clarifying who what the when where and how.
                            • T
                              tomot
                              @thomthom said:
                              "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                              NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
                              my plugins
                              tomot
                              • david_hD
                                david_h
                                I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
                                • P
                                  penumbra
                                  try here;
                                  404 Not Found
                                  (sketchucation.com)
                                    Linked right above the download link - under the "Requirements" header.
                                      Seems there is not an inner faces selection eraser?
                                      • david_hD
                                        david_h
                                        Thanks. I have that and I have run the little installer as well.
                                        It's going now. thank you.
                                        You see. . this is why I really shouldn't be wearing the green badge.
                                          shifo1002000
                                          I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                                          no such file to load -- TT_Lib2/core.rb)
                                          Can you please help?
                                          I also posted on your video on YouTube, sorry for the inconvenience
                                          • massimoM
                                            massimo Moderator
                                            Have you also installed the TT_Lib2 as clearly stated in the very first post under "Requirements"?
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
