    [Request] Script to produce window openings in walls
    9 Posts 6 Posters 1.4k Views 6 Watching
    • Paul RussamP
      Paul Russam
      Hello All,
      I've a small request for a script to punch holes in walls.
      I've attached a multi scene model to show the current steps I go through to get what I want, Its a tedious process that's the same each time except for opening size, position, wall thickness, cill size etc.
      I've written 1 script before but I've forgotten just about everything and would have to start learning all over again which sadly, I don't have the time or energy for.
      Does anybody want to have a go?
      Thanks for looking, Paul
      Window Opening Script request.skp
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
      • M
        mirjman
        i wonder if you could model the window recesses/sills/surrounds as a dynamic component. This way, you could just place your dynamic component, and only have to cut out the front and back of the wall manually (or can you include a dynamic component that cuts holes as well?)
        • TIGT
          There have been several attempts to double-cut twin-skinned walls with 'openings'.
          I have my own version that works OK for what I need, but it needs components pairs... for the outer-opening and inner-opening that are then inexorably linked together by observers... thus it doesn't work on general cutting elements without work - Didier Bur had something similar...
          Mine isn't for general release yet, but...
          • thomthomT
            1001bit plugin has a feature like that. http://www.1001bit.com/products/opening.shtml
            • Paul RussamP
              Paul Russam
              How about instead of trying to cut the 'tunnel' in the wall like a normal pushpull would do, the script builds the required faces instead.
              Dialog prompts for defaults:
              ..Reveal depth
              ..Outer cill width
              ..Outer cill height
              ..Outer cill depth
              ..etc
              1.Select 2 points of rectangle on outer skin of wall
              2.Delete new face
              3.Find inner skin of wall
              --(the thickness of the wall)
              4.Draw identical rectangle on inner skin
              5.Delete new face
              6.Build 4 faces of outer reveal from outer skin to specified depth
              7.Get and apply outer skin material to new faces
              8.Build 4 faces of inner reveal
              --(variable depth to match unknown wall thickness)
              9.Get and apply inner skin material to new faces
              Obviously I've missed out all the steps for the cill etc but as a method would this work? The only thing I see a problem with is step 3, finding the inner skin.
              Paul Russam
              • thomthomT
                You might be interested in one of my plugins I got in the working: http://forums.sketchucation.com/viewtopic.php?f=180&t=19011
                NOTE: you shouldn't use the plugin posted in that thread - it will cause bugplats. But I think I found the cause for it. I'm working around that.
                It's not a solution you can use right now - but it just illustrates what I want to achieve. Can't give any time estimate - things are a bit busy atm.
                • Paul RussamP
                  Paul Russam
                  Thanks Thom, that look interesting, Thanks also for the link to 1001 plugins.
                  Paul Russam
                  • M
                    MartinRinehart
                    I think you will get 90% of what you want if you enlarge the window component's definition to window_and_all_the_surrounding_stuff. Cut a bigger opening and move in a window_and_all_the_surrounding_stuff and you're done. Ditto for doors.
                    http://www.martinrinehart.com/models/tutorial/images/09/window_complete.jpg
                    Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                    • R
                      RickW
                      Windowizer4 will cut the opening in the wall and create any storefront-type glazing for you. You can then quickly add the surrounds using a component or a Dynamic Component. You can also replace the window & frames with a pre-built component, if you want.
                      RickW
                      www.smustard.com
