    Creating curves on an extruded shape that is curved...
    15 Posts 7 Posters 1.3k Views 7 Watching
      land234
      Hard to explain, but how do I create a curve or "wave" look on a shape that is already curved? It would be easy if it was just a rectangle, but with a curved shape I cannot run lines along the shape to extrude out the curves.
      I attached a picture of the shape I would like to create curves into to better illustrate...
      Thanks!! πŸ’š
      • mitcorbM Offline
        mitcorb
        Do you mean a wave or ripple on the curved vertical face, or a wave along the top face?
        Suggestion:
        Fredo6 Tools on Surface, and possibly, Joint/Vector/Normal Push Pull also by Fredo6.
        Suggestion:
        Somehow re-orient the model so that Sandbox tools can be employed, using smoove tool to create contours.
        -BTM's sculpt tool is still in development, but this may help.
        maybe none of the above
          remus
          Heres a quick go using the bend tool in fred06's fredoscale plugin.
          1. Make wave
          2. Use bend
          • Jean LemireJ Offline
            Jean Lemire
            Hi Land234, hi folks.
            See this SU file for ideas.
            Ripple on curved surface.skp
              land234
              Thanks folks! That is what I'm looking to do, with the ripple on the top like that. πŸ‘
              Stupid noob question. What is fred06's fredoscale plugin?
                remus
                http://forums.sketchucation.com/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a&hilit=fredoscale
                  land234
                  wow, thanks for putting that together...! I just downloaded version 7 and was able to look at it, thanks! πŸ‘
                    monk77
                    1. Make wave
                      [attachment=1:8kpf8z01]<!-- ia1 -->wave1.jpg<!-- ia1 -->[/attachment:8kpf8z01]
                    2. Use bend
                      [attachment=0:8kpf8z01]<!-- ia0 -->wave2.jpg<!-- ia0 -->[/attachment:8kpf8z01]
                    Hi Remus,
                    how do you do that? I downloaded fredos scale plugin and there is an option "Radial Bending (free). What must I select to get this nice curve?
                    Cheers
                    monk77
                    my sketchup-animations
                      No, thet's (I guess) "Shape Bender" by Chris Fullmer.
                        remus
                        It was radial bend, and i just grouped the whole thing->selected the group->bend around one of the corners. The plugin does the rest for you.
                          My bad - sorry for the misleading info
                          πŸ˜‰
                            monk77
                            πŸ˜‰
                            No problem Gaieus. πŸ˜„
                            @Remus I have made a group, selected this and then I use the radial blend tool at the top of my mesh (in the middle of the top-surface), but it doesn't work. It is totally deformed. If I use the tool around one of the corners, it does nothing.
                            Can you mark the point in my attachment, where I must use the radial blend tool?
                            Cheers
                            monk77
                            • massimoM Offline
                              massimo Moderator
                              Have you pressed "F4" before you used the bend tool on your shape? This will let you to obtain a smooth curved bend.
                                monk77
                                Thank you Massimo. I got it. F4-key was the right way.
                                Cheers
                                monk77
                                • massimoM Offline
                                  massimo Moderator
                                  You're welcome. πŸ˜„
