    Creating curves on an extruded shape that is curved...
    15 Posts 7 Posters 1.4k Views 7 Watching
      remus
      Heres a quick go using the bend tool in fred06's fredoscale plugin.
      1. Make wave
      2. Use bend
      • Jean LemireJ Offline
        Jean Lemire
        Hi Land234, hi folks.
        See this SU file for ideas.
        Ripple on curved surface.skp
          land234
          Thanks folks! That is what I'm looking to do, with the ripple on the top like that. πŸ‘
          Stupid noob question. What is fred06's fredoscale plugin?
            remus
            http://forums.sketchucation.com/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a&hilit=fredoscale
              land234
              wow, thanks for putting that together...! I just downloaded version 7 and was able to look at it, thanks! πŸ‘
                monk77
                1. Make wave
                  [attachment=1:8kpf8z01]<!-- ia1 -->wave1.jpg<!-- ia1 -->[/attachment:8kpf8z01]
                2. Use bend
                  [attachment=0:8kpf8z01]<!-- ia0 -->wave2.jpg<!-- ia0 -->[/attachment:8kpf8z01]
                Hi Remus,
                how do you do that? I downloaded fredos scale plugin and there is an option "Radial Bending (free). What must I select to get this nice curve?
                Cheers
                monk77
                my sketchup-animations
                  No, thet's (I guess) "Shape Bender" by Chris Fullmer.
                    remus
                    It was radial bend, and i just grouped the whole thing->selected the group->bend around one of the corners. The plugin does the rest for you.
                      My bad - sorry for the misleading info
                      πŸ˜‰
                        monk77
                        πŸ˜‰
                        No problem Gaieus. πŸ˜„
                        @Remus I have made a group, selected this and then I use the radial blend tool at the top of my mesh (in the middle of the top-surface), but it doesn't work. It is totally deformed. If I use the tool around one of the corners, it does nothing.
                        Can you mark the point in my attachment, where I must use the radial blend tool?
                        Cheers
                        monk77
                        • massimoM Offline
                          massimo Moderator
                          Have you pressed "F4" before you used the bend tool on your shape? This will let you to obtain a smooth curved bend.
                            monk77
                            Thank you Massimo. I got it. F4-key was the right way.
                            Cheers
                            monk77
                            • massimoM Offline
                              massimo Moderator
                              You're welcome. πŸ˜„
