    Creating curves on an extruded shape that is curved...
    15 Posts 7 Posters 1.6k Views 7 Watching
    • Jean LemireJ Offline
      Jean Lemire
      Hi Land234, hi folks.
      See this SU file for ideas.
      Ripple on curved surface.skp
        land234
        Thanks folks! That is what I'm looking to do, with the ripple on the top like that. πŸ‘
        Stupid noob question. What is fred06's fredoscale plugin?
          remus
          404 Not Found
          (forums.sketchucation.com)
            land234
            wow, thanks for putting that together...! I just downloaded version 7 and was able to look at it, thanks! πŸ‘
              monk77
              @remus said:
              Heres a quick go using the bend tool in fred06's fredoscale plugin.
              1. Make wave
                [attachment=1:8kpf8z01]<!-- ia1 -->wave1.jpg<!-- ia1 -->[/attachment:8kpf8z01]
              2. Use bend
                [attachment=0:8kpf8z01]<!-- ia0 -->wave2.jpg<!-- ia0 -->[/attachment:8kpf8z01]
              Hi Remus,
              how do you do that? I downloaded fredos scale plugin and there is an option "Radial Bending (free). What must I select to get this nice curve?
              Cheers
              monk77
              my sketchup-animations
                No, thet's (I guess) "Shape Bender" by Chris Fullmer.
                  remus
                  It was radial bend, and i just grouped the whole thing->selected the group->bend around one of the corners. The plugin does the rest for you.
                    My bad - sorry for the misleading info
                    πŸ˜‰
                      monk77
                      πŸ˜‰
                      No problem Gaieus. πŸ˜„
                      @Remus I have made a group, selected this and then I use the radial blend tool at the top of my mesh (in the middle of the top-surface), but it doesn't work. It is totally deformed. If I use the tool around one of the corners, it does nothing.
                      Can you mark the point in my attachment, where I must use the radial blend tool?
                      Cheers
                      monk77
                      • massimoM Offline
                        massimo Moderator
                        Have you pressed "F4" before you used the bend tool on your shape? This will let you to obtain a smooth curved bend.
                          monk77
                          Thank you Massimo. I got it. F4-key was the right way.
                          Cheers
                          monk77
                          • massimoM Offline
                            massimo Moderator
                            You're welcome. πŸ˜„
