    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 438.3k Views 87 Watching
      Got a feature request: Make it use the Importer class: http://code.google.com/apis/sketchup/docs/ourdoc/importer.html
      That way it can be found under the native importer options.
        hm...
        Importing a OBJ file now, I'm getting lots of Error: 666 in the Ruby Console. πŸ˜•
          Sometimes OBJ files throw an error [I suspect that it depends how they were 'written' originally - there are several different 'formats' - e.g. define some vertices then related faces per group... or define all vertices then all faces en mass; which is more difficult to read 'manually' too] - the geometry for the face is invalid - the three points are perhaps colinear or [effectively] coincident - so I get it to put up an error instead of crashing... The 666 is a longstanding joke with Rich πŸ˜’ http://forums.sketchucation.com/viewtopic.php?p=316402#p316402
          Although it throws the errors up it usually seems to make the expected geometry - so it's difficult to see what's 'gone wrong' πŸ˜•
          You can of course easily tweak the 666 rescue message to include the Exception - but frankly I found that little use either...
          My importer is not [always] as good as the compiled dll version that is available.
          For MAC it is the only option.
            There is a compiled version?
              Here http://forums.sketchucation.com/viewtopic.php?p=316470#p316470
              Fluid's free OBJ importer [PC only]...
                Fluid obj importer in the extensions forum.
                  Sorry, I posted this earlier but lost web connection.
                  • N Offline
                    niks
                    hi Tig..thank you for this ama 😍 ing...plugin
                      capsssa
                      Please,
                      i need help.
                      I've got the version 7 pro, i am on a mac, but when i installed this plugin it doesn't work.
                      I am on a mac. When i poen sketchup the plugin is absent.
                      Can you help me, please ?
                        You have probably installed it in the wrong folder - check where your MAC Plugins folder is and ensure you put it in there...
                        It is accessed off the Plugins menu.
                        I would recommend the FluidImporter but I think it's PC only...
                        • chippwaltersC Offline
                          chippwalters
                          Hey TIG,
                          How come this file (simple) won't import with map? I created it using UV Mapper Pro, which is pretty standard IMO. Any insight you might have would help greatly!!!
                          http://dl.dropbox.com/u/3788438/avain.zip
                          Currently working with Cross-Reality technologies
                            Chipp
                            This tool is now plenty old and there's a much better/faster [free, PC only] one available here...
                            [follow the link to the download page here
                            http://www.fluidray.com/downloads]
                            I recommend you try that.
                              chippwalters
                              @tig said:
                              Chipp
                              Here's its result, which I take is what you want ?[attachment=0:2wlcddqw]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2wlcddqw]
                              Thanks TIG. Just what the doctor ordered πŸ˜„
                              I'm using a Mac these days, but I've got a Virtual Win version of SketchUp. I'll check it out!
                              • W Offline
                                wootwoots
                                I tried your plugin, and saddly it didnt import anything.
                                I tried the fluid obj importer, and for a single cube google sketchup just crash 😞
                                • O Offline
                                  oldman-pit
                                  well done TIG, thanks a lot! πŸ‘
                                    A bit more info would mean that we could help.
                                    • LanaL Offline
                                      Lana
                                      Thanks Tig.You are good. 😍
                                      • olisheaO Offline
                                        olishea
                                        Hey TIG,
                                        I'm having an issue with this plugin. Installed on latest SU, Mac OSX.
                                        After I have selected the model units (I have tried all of them just in case) nothing happens on import; no loading, nothing. I have tried all three import options. The OBJ i am importing is not complex and has no materials set yet. The other JF OBJ Importer plugin works OK, but I have no option of import units. I have also imported the model as 3DS no probs.
                                        Any help would be much appreciated.
                                        oli
                                          @olishea said:
                                          Hey TIG,
                                          There's a better/faster free Fluid OBJimporter for PC only 😞
                                          The Model units don't matter BUT the imported units are important because if the original OBJ is in 'm' and you import in 'mm' it'll be 1000 times too small and we already know that making tiny geometry makes Sketchup fall over...
                                          So try in the largest units available [meters?].
                                          Some OBJ files have an obscure format.
                                          You could try in/out of Blender to see if that sorts out the file formating ??
                                          Alternatively PM me the OBJ and I'll see if I can SKP-ify it for you ???
                                          • olisheaO Offline
                                            olishea
                                            Don't worry, I have imported and saved as SKP, thanks for the offer. I just wanted to use your plugin due to the units feature....because like you say geometry can play up when the model is tiny. I have got round the issue importing as 3DS with merged coplanar, where I can set units. Otherwise all I can do is scale up in blender then import using the other OBJ importer.
                                            oli
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
