    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 448.6k Views 87 Watching
    • chippwaltersC
      chippwalters
      Hey TIG,
      How come this file (simple) won't import with map? I created it using UV Mapper Pro, which is pretty standard IMO. Any insight you might have would help greatly!!!
      http://dl.dropbox.com/u/3788438/avain.zip
      Currently working with Cross-Reality technologies
        Chipp
        This tool is now plenty old and there's a much better/faster [free, PC only] one available here...
        http://forums.sketchucation.com/viewtopic.php?p=316470#p316470
        [follow the link to the download page here
        http://www.fluidray.com/downloads]
        I recommend you try that.
        • chippwaltersC
          chippwalters
          @tig said:
          Chipp
          Here's its result, which I take is what you want ?[attachment=0:2wlcddqw]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2wlcddqw]
          Thanks TIG. Just what the doctor ordered πŸ˜„
          I'm using a Mac these days, but I've got a Virtual Win version of SketchUp. I'll check it out!
          • W
            wootwoots
            I tried your plugin, and saddly it didnt import anything.
            I tried the fluid obj importer, and for a single cube google sketchup just crash 😞
            • O
              oldman-pit
              well done TIG, thanks a lot! πŸ‘
                A bit more info would mean that we could help.
                • LanaL
                  Lana
                  Thanks Tig.You are good. 😍
                  • olisheaO
                    olishea
                    Hey TIG,
                    I'm having an issue with this plugin. Installed on latest SU, Mac OSX.
                    After I have selected the model units (I have tried all of them just in case) nothing happens on import; no loading, nothing. I have tried all three import options. The OBJ i am importing is not complex and has no materials set yet. The other JF OBJ Importer plugin works OK, but I have no option of import units. I have also imported the model as 3DS no probs.
                    Any help would be much appreciated.
                    oli
                      @olishea said:
                      Hey TIG,
                      There's a better/faster free Fluid OBJimporter for PC only 😞
                      The Model units don't matter BUT the imported units are important because if the original OBJ is in 'm' and you import in 'mm' it'll be 1000 times too small and we already know that making tiny geometry makes Sketchup fall over...
                      So try in the largest units available [meters?].
                      Some OBJ files have an obscure format.
                      You could try in/out of Blender to see if that sorts out the file formating ??
                      Alternatively PM me the OBJ and I'll see if I can SKP-ify it for you ???
                      • olisheaO
                        olishea
                        Don't worry, I have imported and saved as SKP, thanks for the offer. I just wanted to use your plugin due to the units feature....because like you say geometry can play up when the model is tiny. I have got round the issue importing as 3DS with merged coplanar, where I can set units. Otherwise all I can do is scale up in blender then import using the other OBJ importer.
                        oli
                          mingjae
                          Hello,
                          i need a help sir, the plugins wont load the .obj file,
                          but at the text box bottom of sketchup it processing something but just in a second..
                          my .obj file is around 6Mbs
                          I am trying all the 3 methods,with textures,no material, and as mesh but no object were created, the obj_importer.rb is on the plugins folder at Google Sketchup8 directory,
                          and the plugin menu is loaded at the SketchUp>Plugins..
                          my OS is Windows7 Ultimate 64bit,
                          my Trimble SketchUp8 ver is 8.0.16846
                          on larger .obj file (76Mb) the plugin processing about 4secs but still no object were created, did I miss something to load the models?
                          thx
                            The Fluid OBJimporter is better and faster.
                            If your OBJ file is in say 'm' and you import as 'mm' the geometry size can be so small nothing is created.
                            Some OBJ files also have incompatible formats...
                            A 6Mb file should take some time to load.
                            If you have the Ruby Console open are there any messages...?
                              mingjae
                              yes mr.TIG, fluidImporter can successfully load .obj models but it 90% will crashes if i try to render the scene using vray, 😞
                              and yes, there's a lot of text if i open the ruby console, these are the texts written:
                              Processing 'C:\Users\John\Downloads\Compressed\VizPeople_Free_3d_Models_Sofas\Ikea_kramfors\Ikea_kramfors.obj'...
                              Error: 666
                              Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
                              D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:317:in add' D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:317:in run'
                              D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:317:in map' D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:317:in run'
                              D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:229:in each' D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:229:in run'
                              D:/Program Files (x86)/Google/Google SketchUp 8/Plugins/obj_importer.rb:365
                              quietly_force_sync_mats_cb just called
                              I try another .obj files and still wont load the models,
                              here is one of the model sir:
                              http://www.mediafire.com/?7975kudbfcvab7d
                                Try to model without V-Ray loaded and see if you get less issues then.
                                I wrote V-Ray Tools so I could disable V-Ray under Preferences > Extensions and then load V-Ray only when I need to render. Makes SU start faster and avoid various issues that VfSU causes.
                                http://sketchucation.com/forums/viewtopic.php?t=15491
                                  mingjae
                                  woaa.. thx sir now it can load some of the file but some still cannot be loaded..
                                  and yes,much more slower than fluidimporter... πŸ‘Š
                                  thx sketchUcation! 😍
                                    John514
                                    Hi! Very usefull plugin BUT it appears it isnt working for me. I run it, select my .obj click OK and then Nothing! Just as if I didnt do anything! What could be wrong?
                                      What units does the OBJ file use?
                                      Try assuming they are 'meters' - this 'biggest size' is more likely to work and avoid 'tiny geometry failures'.
                                      Are there any Ruby Console messages ??
                                      Do you have a small OBJ file you can share [+MTL?] ??
                                      Because you are on Windows have you considered using the faster Fluid-Importer that has just been discussed here - it's faster too... πŸ˜•
                                        John514
                                        I export a .FBX file with bake occlusion through LightUp (demo)
                                        Then I convert it to .obj with Autodesk`s converter and I try getting it back to sketchup.
                                        So yes the units were meters when I created it.
                                        Here is my Ruby messages. It appears there is an error:
                                        Processing 'K:\Users\ΓΙΑΝΝΗΣ\Desktop\SSthes\AutoSave_OSE Thess_lightup(no scene)_2013-03-19_2204.obj'...
                                        Error: #<RangeError: 915 out of char range>
                                        K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:163:in chr' K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:163:in run'
                                        K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:163:in map' K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:163:in run'
                                        K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:365
                                        K:/Program Files/Google/Google SketchUp 8/Plugins/obj_importer.rb:163:in `call'
                                        That (ΓΙΑΝΝΗΣ) thing is my username! Its Greek.
                                          Might be an issue with Unicode characters. Try using a path and filename with only Latin characters.
                                            John514
                                            You were right! Thank you. The textures didnt show up, but I`ll try a new export and see how that goes.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
