    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.1m Views 477 Watching
      Can you share or show an example mesh?
      • fredo6F Offline
        fredo6
        @hieru said:
        OK, so I've tried disabling all other plugins, but no luck.
        I've also completely removed Round Corner and LibFredo from the plugin folder and reinstalled them. Again no luck....when I try anything other than Sharp Corners I get the warning "Invalid (Property filter)".
        I haven't tried installing manually (without the Sketchucation tool).
        The message "invalid (property filter)" comes when you select an edge with NO face.
        So you may want to inspect your model and see if there is no hidden edge defect.
        Fredo
        • HieruH Offline
          Hieru
          Thanks guys, but I've solved the problem now.
          For some reason the edge properties were set by default to 'soft' only. Not sure if that's a bug or a d'oh! moment on my behalf.
          www.davidhier.co.uk
            Diago
            Hi there a question. Does Round Corner work on Sketchup 2015 on Mac? If so, how can I install it? thanks in advance.
            • RedFoxyR Offline
              RedFoxy
              Hi there.
              I have been looking through the topic but can't find any satisfying answer to my problem... I am working on Sketchup 2015 for mac and the RoundCorner plugin keeps crushing it pretty much every single time i try to use it... I have checked all my plugins and they're up to date, so is the v-ray version... Also don't have any error messages when I run the program. But all the plugin needs to crush is simply trying to select or unselect ANY line and bam - there's the bug splat... Any ideas what may be causing that? I'm running out of patience πŸ˜› 😑
                Try disabling the V-ray plugin and see if you still get the crash.
                  Diago
                  Red Foxy, do you have v-ray for SU 2015 for Mac? could you please upload the file? I really don't find any v-ray for SU 2015 for Mac.
                  • RedFoxyR Offline
                    RedFoxy
                    Thanks for the quick reply... well, i did that, checked some edges, got all excited, added one more and well.. yeah. bug splat... 😞 So still no solution... Will probably try unchecking and trying all the plugins one by one, maybe i'll find something responsible for that πŸ˜• Thanks anyway for the suggestion...
                    Yeah, got it from the chaosgroup website πŸ˜„
                    http://www.chaosgroup.com/en/2/vrayforsketchup.html
                      Maybe you could post the SKP file that you're trying to run Round Corner on?
                      • RedFoxyR Offline
                        RedFoxy
                        the whole file is quite big, unless you mean a separate component then sure, but it crashes on things as simple as a cube.. I managed to get 2 surfaces rounded however it took me like 6 attempts or something πŸ˜„ this thing really teaches you patience.
                        komoda 120x50x76.skp
                          What edges are you trying to round over? And what values are you using for Offset and the Number of sides?
                          Patience is good. πŸ˜‰
                          • RedFoxyR Offline
                            RedFoxy
                            Just the sides of the main box and the parameters were 2mm and 2 sides.
                              OK. I just tried it on my computer and it worked fine. I only selected the front and back vertical edges and the bottom edge. How were you making the selection? Is it possible you were selecting the top edge where the round over has already been done?
                              • RedFoxyR Offline
                                RedFoxy
                                I don't think so, i just select the four vertical edges and try to run the roundcorner... As I said before, sometimes it works but it crashes on rather stupid moments such as unselecting a selected edge or something else as simple as that...
                                Sometimes i feel like with sketchup patience is everything πŸ˜„
                                  I quickly redrew your cabinet and then rounded over the edges on the top and sides in one go.
                                  I double clicked with Select while holding the Ctrl key (Option on Mac) on all three sides in turn to select their edges and then ran the tool once.
                                  • RedFoxyR Offline
                                    RedFoxy
                                    [attachment=1:358glolk]<!-- ia1 -->Screenshot - 12_19_2014 , 4_51_30 PM.png<!-- ia1 -->[/attachment:358glolk]
                                    [attachment=0:358glolk]<!-- ia0 -->Screenshot - 12_19_2014 , 4_53_49 PM.png<!-- ia0 -->[/attachment:358glolk]
                                    Hmmm... however tempting redrawing around 60 different pieces of office furniture is πŸ˜„ I have been encountering this problem with other objects before while working on a completely different project, so from that I take it's rather the issue of program/plugins incompatibility rather than the objects themselves... Thank you very much for trying to help, I suppose this problem is gonna stay unsolved for now, will definitely have to run all the plugins separately to see which one may be causing the errors..
                                      Prefer to work in Scale *100 and at the end Scale /100
                                      At this Scale (mm)Sketchup don't like very tiny segments, surfaces...
                                        Pilou, at this scale SketchUp rounded over the corners just fine and filled in all the face on my installation.
                                        • RedFoxyR Offline
                                          RedFoxy
                                          Thank you for the suggestion but that was never an issue for me... worked completely fine in 2014. 😒
                                            AcesHigh
                                            RedFoxy, do you still have 2014 installed?
                                            You can just open 2015 and 2014. Open your file first in 2015. Then in 2014 (it will say it will have to open as read only). Then round corner the objects you want in 2014 and copy to the main file in 2015 (saving once in a while in 2015).
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 74
                                            • 75
                                            • 49 / 75
