    1.5k Posts 476 Posters 3.9m Views 476 Watching
      What edges are you trying to round over? And what values are you using for Offset and the Number of sides?
      Patience is good. πŸ˜‰
      • RedFoxyR Offline
        RedFoxy
        Just the sides of the main box and the parameters were 2mm and 2 sides.
          OK. I just tried it on my computer and it worked fine. I only selected the front and back vertical edges and the bottom edge. How were you making the selection? Is it possible you were selecting the top edge where the round over has already been done?
          • RedFoxyR Offline
            RedFoxy
            I don't think so, i just select the four vertical edges and try to run the roundcorner... As I said before, sometimes it works but it crashes on rather stupid moments such as unselecting a selected edge or something else as simple as that...
            Sometimes i feel like with sketchup patience is everything πŸ˜„
              I quickly redrew your cabinet and then rounded over the edges on the top and sides in one go.
              I double clicked with Select while holding the Ctrl key (Option on Mac) on all three sides in turn to select their edges and then ran the tool once.
              • RedFoxyR Offline
                RedFoxy
                [attachment=1:358glolk]<!-- ia1 -->Screenshot - 12_19_2014 , 4_51_30 PM.png<!-- ia1 -->[/attachment:358glolk]
                [attachment=0:358glolk]<!-- ia0 -->Screenshot - 12_19_2014 , 4_53_49 PM.png<!-- ia0 -->[/attachment:358glolk]
                Hmmm... however tempting redrawing around 60 different pieces of office furniture is πŸ˜„ I have been encountering this problem with other objects before while working on a completely different project, so from that I take it's rather the issue of program/plugins incompatibility rather than the objects themselves... Thank you very much for trying to help, I suppose this problem is gonna stay unsolved for now, will definitely have to run all the plugins separately to see which one may be causing the errors..
                  Prefer to work in Scale *100 and at the end Scale /100
                  At this Scale (mm)Sketchup don't like very tiny segments, surfaces...
                    Pilou, at this scale SketchUp rounded over the corners just fine and filled in all the face on my installation.
                    • RedFoxyR Offline
                      RedFoxy
                      Thank you for the suggestion but that was never an issue for me... worked completely fine in 2014. 😒
                        AcesHigh
                        RedFoxy, do you still have 2014 installed?
                        You can just open 2015 and 2014. Open your file first in 2015. Then in 2014 (it will say it will have to open as read only). Then round corner the objects you want in 2014 and copy to the main file in 2015 (saving once in a while in 2015).
                          define
                          Hello Fredo,
                          can't thank you enough for all your plugins!!! Donate folks!! At the end of the day
                          we will have to open our refrigerators door - isn't it?
                          I have a question:
                          When inspecting the icons for 'RoundCorner' I stumbled upon one which is labeled 'CustomProfile'.
                          It however don't seem to be implemented. Did you work on this as well?
                          ...absolutely amazed by your work and with maximum respect
                          Klaus
                          • fredo6F Offline
                            Klaus,
                            Custom profiles (based on a quarter definition of profile) is something that I have included in the code, but I would need to build a kind of GUI to activate it in the script.
                            see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20485%26amp;start=30#p172163
                            • PixeroP Offline
                              Pixero
                              Please do. πŸ˜‰
                              Another small request.
                              Would it be possible to make the scripts create quads only? As it is now it also creates triangles.
                                How would you expect the result would be in quads for that example you posted?
                                • fredo6F Offline
                                  I think it is rather something like this:
                                  Coincidentally, I was just giving an other look at RoundCorner using subdivisions techniques, essentially to generalize usage to complex situations where a pure geometrical construction is not possible.
                                  • pbacotP Offline
                                    Would it be something like this?
                                    EDIT --oh no, the other faces get ruined for quads--I tried applying texture and just realized this and came back to find your post below, Fredo!
                                      [attachment=0:2nffscfk]<!-- ia0 -->Quad round corner.png<!-- ia0 -->[/attachment:2nffscfk]
                                      Yea, that type of rounding would be great!
                                      πŸ‘ πŸ‘
                                      • fredo6F Offline
                                        @thomthom said:
                                        πŸ‘ πŸ‘
                                        I am not so familar with subdivision. But I think you are, as you work on your SubDivide plugin!
                                        • fredo6F Offline
                                          [attachment=4:1tjc0skc]<!-- ia4 -->triangles.JPG<!-- ia4 -->[/attachment:1tjc0skc]
                                          Another possibility is the double rounding
                                          Basically you proceed in 2 steps:
                                          1. Round the vertical edge by an offset A (here A = 0.2m)
                                            [attachment=3:1tjc0skc]<!-- ia3 -->Double Rounding 1.png<!-- ia3 -->[/attachment:1tjc0skc][attachment=0:1tjc0skc]<!-- ia0 -->Double Rounding 11.png<!-- ia0 -->[/attachment:1tjc0skc]
                                          2. Then Round the top edges by an offset B, such as B is lower than A (here B = 0.15 m)
                                            [attachment=2:1tjc0skc]<!-- ia2 -->Double rounding 2.png<!-- ia2 -->[/attachment:1tjc0skc][attachment=1:1tjc0skc]<!-- ia1 -->Double Rounding 3.png<!-- ia1 -->[/attachment:1tjc0skc]
                                          I can maybe automate this type of double rounding in the Plugin
                                            Fredo, it would be very nice if you could implement double rounding. That's essentially the way the real corners would get rounded on the models I draw.
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 74
                                            • 75
                                            • 49 / 75
