    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Move groups with different measures?
    55 Posts 4 Posters 29.4k Views 4 Watching
      Many thx! โ˜€
      It's always the more easy ans usefull who is not written as example ๐Ÿ˜’
        ??? = error : in โ€˜initializeโ€™: undefined local variable or method โ€˜boundboxโ€™ ๐Ÿ˜ฎ
        model = Sketchup.active_model
        entities = model.entities
        selection = model.selection
        #groups = []
        xp=100  # Pivot Point
        yp=100
        zp=100
        xc=0  #Center Point of the grouped object
        yc=0
        zc=0
        xe=0  #End Point of the grouped object
        ye=0
        ye=0
        selection.each do |e| # update!
          # Skip all entities that aren't groups
          next unless e.is_a? Sketchup;;Group
          # Now we process the groups
         center = boundbox.center
                xc= boundbox.center.x # ??? error
        	yc= boundbox.center.y
        	zc= boundbox.center.z
        xe=xc
        ye=yc
        ze=zc
        if xc<xp
        xe =xc - 100
          if xc>xp
        xe =xc +100
        if yc<yp
        ye =yc - 100
          if yc>yp
        ye =yc +100
        if zc<zp
        ze =zc - 100
          if zc>zp
        ze =zc +100
          point = Geom;;Point3d.new xe,ye,ze
          t = Geom;;Transformation.new point
          # Apply the transformation
          e.transform!(t)
          That's because of center = boundbox.center <- you haven't referenced boundbox yet.
          change to
          center = e.bounds.center
             xc= center.x
             yc= center.y
             zc= center.z
            Thx! โ˜€
            More easy with that ๐Ÿ˜„ Works like a charm ๐Ÿ˜Ž
            I can now test some natures of explodes ๐Ÿ’š
              Funny thing ๐Ÿ˜„
                Looking good Pilou!
                Instant assembly drawings! ๐Ÿ˜„ This should come in handy.
                  Instant assembly
                  Alas for the inverse, that must be more tricky! ๐Ÿ˜•
                  Better is use the Undo ๐Ÿ’š
                    hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
                    though, that will fail if the user moves anything...
                    Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
                    • Chris FullmerC Offline
                      Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
                      I wrote that crazy scrambler script a while ago that does this and it worked very well.
                      Chris
                      All my Plugins I've written
                        In theory that must be more easy ๐Ÿ˜‰
                        Just select that you want and apply a "negative" translation : a deflation ๐Ÿ˜‰
                        Maybe my next ๐Ÿ˜„
                        And the above is not yet perfect! The Pivot Point seems not have the wished result wanted ๐Ÿ˜’
                        be continued...
                        Ps When Groups or Components are nested how to process automatically?
                        A plug for make each components individual is maybe existing?
                        Edit
                        one exist for group by TIG Explode2groups
                        miss now somethings transform Transform2goups or Explode2Components ๐Ÿ˜„
                          @Chris Any chance to see it somewhere? ๐Ÿ˜„
                          PS
                          Edit
                          miss now somethings for components Transform2goups or Explode2Components
                            take the componentInstance, add it to a group, then explode the component instance.
                            And I posted my scrambler script here. I'll see if I can find the thread.
                            Chris
                              @Chris thx for the Info โ˜€
                              Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual)
                              (last icon)
                                Some tests ๐Ÿ’š Put the code inside the WebConsole by Jim Foltz
                                Press "Eval" button and have fun ๐Ÿ˜„
                                Veyron model is from 3Dwarehouse!
                                xp=100  # Pivot Point (as you want)
                                yp=100
                                zp=100
                                q=50 # Measure of translation (as you want)
                                  # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                                  next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                                 center = e.bounds.center #Center Point of the grouped object
                                   xc= center.x
                                   yc= center.y
                                   zc= center.z
                                xe=xc #End Point of the grouped object
                                ye=yc
                                ze=zc
                                if xc<xp
                                 xe =xc - q
                                if xc>xp
                                 xe =xc + q
                                if yc<yp
                                 ye =yc - q
                                if yc>yp
                                 ye =yc + q
                                if zc<zp
                                 ze =zc - q
                                if zc>zp
                                 ze =zc + q
                                  e.transform!(t)
                                  Yep!!! THX! Miracle that is working! ๐Ÿ˜
                                  Sure I should read the Api document before ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ But I had risked the trick ๐Ÿ’š
                                  So my second script was a new speedy success and a big lesson ๐Ÿ˜„
                                  groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::ComponentInstance)}
                                  groups.each{|ComponentInstance|zeds.push([ComponentInstance.bounds.min.z, index])
                                  Copy my code follow in the Web console from Jim Foltz โ— โ— โ—
                                  (if you have components use the file linked )
                                      model.start_operation("Move in Z")
                                      zeds=[]
                                      index=0
                                      sorted_groups=[]
                                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                                      groups.each{|group|zeds.push([group.bounds.min.z, index])
                                         index+=1
                                      zeds.sort!
                                      zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                                      ### sorted_groups is now groups sorted by z
                                      z = 0.0
                                      sorted_groups.each do |e| # update!
                                        t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                                        e.transform!(t)
                                        z = z + 100.cm
                                    model.commit_operation
                                    return nil
                                  Some help for fun variations ๐Ÿ˜„
                                  http://forums.polyloop.net/picture.php?albumid=23&pictureid=421
                                  Undrop_component.zip
                                  • 3 / 3
