    Move groups with different measures?
    55 Posts 4 Posters 32.9k Views 4 Watching
      boundbox.center returns an object of type Point3d. You can check what an object is by checking the .class value of an object. That gives you an indication to where to look.
      xc= boundbox.center.x
      yc= boundbox.center.y
      zc= boundbox.center.z
        Many thx! โ˜€
        It's always the more easy ans usefull who is not written as example ๐Ÿ˜’
          ??? = error : in โ€˜initializeโ€™: undefined local variable or method โ€˜boundboxโ€™ ๐Ÿ˜ฎ
          model = Sketchup.active_model
          entities = model.entities
          selection = model.selection
          #groups = []
          xp=100  # Pivot Point
          yp=100
          zp=100
          xc=0  #Center Point of the grouped object
          yc=0
          zc=0
          xe=0  #End Point of the grouped object
          ye=0
          ye=0
          selection.each do |e| # update!
            # Skip all entities that aren't groups
            next unless e.is_a? Sketchup;;Group
            # Now we process the groups
           center = boundbox.center
                  xc= boundbox.center.x # ??? error
          xe=xc
          ye=yc
          ze=zc
          if xc<xp
          xe =xc - 100
            if xc>xp
          xe =xc +100
          if yc<yp
          ye =yc - 100
            if yc>yp
          ye =yc +100
          if zc<zp
          ze =zc - 100
            if zc>zp
          ze =zc +100
            point = Geom;;Point3d.new xe,ye,ze
            t = Geom;;Transformation.new point
            # Apply the transformation
            e.transform!(t)
            That's because of center = boundbox.center <- you haven't referenced boundbox yet.
            change to
            center = e.bounds.center
               xc= center.x
               yc= center.y
               zc= center.z
              Thx! โ˜€
              More easy with that ๐Ÿ˜„ Works like a charm ๐Ÿ˜Ž
              I can now test some natures of explodes ๐Ÿ’š
                Funny thing ๐Ÿ˜„
                  Looking good Pilou!
                  Instant assembly drawings! ๐Ÿ˜„ This should come in handy.
                    Instant assembly
                    Alas for the inverse, that must be more tricky! ๐Ÿ˜•
                    Better is use the Undo ๐Ÿ’š
                      hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
                      though, that will fail if the user moves anything...
                      Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
                      • Chris FullmerC Offline
                        Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
                        I wrote that crazy scrambler script a while ago that does this and it worked very well.
                          In theory that must be more easy ๐Ÿ˜‰
                          Just select that you want and apply a "negative" translation : a deflation ๐Ÿ˜‰
                          Maybe my next ๐Ÿ˜„
                          And the above is not yet perfect! The Pivot Point seems not have the wished result wanted ๐Ÿ˜’
                          be continued...
                          Ps When Groups or Components are nested how to process automatically?
                          A plug for make each components individual is maybe existing?
                          Edit
                          one exist for group by TIG Explode2groups
                          miss now somethings transform Transform2goups or Explode2Components ๐Ÿ˜„
                            @Chris Any chance to see it somewhere? ๐Ÿ˜„
                            PS
                            Edit
                            miss now somethings for components Transform2goups or Explode2Components
                              take the componentInstance, add it to a group, then explode the component instance.
                              And I posted my scrambler script here. I'll see if I can find the thread.
                                @Chris thx for the Info โ˜€
                                Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual)
                                (last icon)
                                  Some tests ๐Ÿ’š Put the code inside the WebConsole by Jim Foltz
                                  Press "Eval" button and have fun ๐Ÿ˜„
                                  Veyron model is from 3Dwarehouse!
                                  xp=100  # Pivot Point (as you want)
                                  yp=100
                                  zp=100
                                  q=50 # Measure of translation (as you want)
                                    # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                                    next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                                   center = e.bounds.center #Center Point of the grouped object
                                     xc= center.x
                                     yc= center.y
                                     zc= center.z
                                  xe=xc #End Point of the grouped object
                                  ye=yc
                                  ze=zc
                                  if xc<xp
                                   xe =xc - q
                                  if xc>xp
                                   xe =xc + q
                                  if yc<yp
                                   ye =yc - q
                                  if yc>yp
                                   ye =yc + q
                                  if zc<zp
                                   ze =zc - q
                                  if zc>zp
                                   ze =zc + q
                                    e.transform!(t)
                                    Yep!!! THX! Miracle that is working! ๐Ÿ˜
                                    Sure I should read the Api document before ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ But I had risked the trick ๐Ÿ’š
                                    So my second script was a new speedy success and a big lesson ๐Ÿ˜„
                                    groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::ComponentInstance)}
                                    groups.each{|ComponentInstance|zeds.push([ComponentInstance.bounds.min.z, index])
                                    Copy my code follow in the Web console from Jim Foltz โ— โ— โ—
                                    (if you have components use the file linked )
                                        model.start_operation("Move in Z")
                                        zeds=[]
                                        index=0
                                        sorted_groups=[]
                                        groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                                        groups.each{|group|zeds.push([group.bounds.min.z, index])
                                           index+=1
                                        zeds.sort!
                                        zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                                        ### sorted_groups is now groups sorted by z
                                        z = 0.0
                                        sorted_groups.each do |e| # update!
                                          t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                                          e.transform!(t)
                                          z = z + 100.cm
                                      model.commit_operation
                                      return nil
                                    Some help for fun variations ๐Ÿ˜„
                                    http://forums.polyloop.net/picture.php?albumid=23&pictureid=421
                                    Undrop_component.zip
                                    • 3 / 3
