    Move groups with different measures?
    55 Posts 4 Posters 33.5k Views 4 Watching
      Thx I had missed this one ๐Ÿ˜‰
        It'd help if you posted the error messages.
        However, I can still see the problem here. Sketchup::Component isn't an SU object. Check the manual, you have Sketchup::ComponentDefinition and Sketchup::ComponentInstance. In your case you're looking for a Sketchup::ComponentInstance.
          I have replaced "Group" by "Component" but seems that is not so simple ๐Ÿ’š
          groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Component)}
              groups.each{|component|zeds.push([component.bounds.min.z, index])
          Else I can yet nest a component inside a group color transparent ๐Ÿ’š
          That works fine (just disable Edges visible) but I suppose there is another thing ๐Ÿ˜„
            @ Tig Some cryptic but I will see that ๐Ÿ˜‰
            Joint an image for no ambiguities
            So here the increment is 300 cm
            Edit sorry I have not seen all these speedy results! ๐Ÿ˜ณ
            @Thomthom! Yes that is that ! e.transform!(t) ๐Ÿ˜‰
              Come back in these very dangerous territories ๐Ÿ’š
              As I understand that retrieve the center XYZ of the bounding box group by
               center = boundbox.center
              but how give these 3 values(?) to these 3 variables ? ๐Ÿ˜’
              xc= ?
              yc= ?
              zc= ?
              must be trivial but yet some foggy for me ๐Ÿ˜„
              PS I read the API from the end to the start, and inverse but this stay mysterious found anything except that ๐Ÿ’š
                boundbox.center returns an object of type Point3d. You can check what an object is by checking the .class value of an object. That gives you an indication to where to look.
                xc= boundbox.center.x
                yc= boundbox.center.y
                zc= boundbox.center.z
                  Many thx! โ˜€
                  It's always the more easy ans usefull who is not written as example ๐Ÿ˜’
                    ??? = error : in โ€˜initializeโ€™: undefined local variable or method โ€˜boundboxโ€™ ๐Ÿ˜ฎ
                    model = Sketchup.active_model
                    entities = model.entities
                    selection = model.selection
                    #groups = []
                    xp=100  # Pivot Point
                    yp=100
                    zp=100
                    xc=0  #Center Point of the grouped object
                    yc=0
                    zc=0
                    xe=0  #End Point of the grouped object
                    ye=0
                    ye=0
                    selection.each do |e| # update!
                      # Skip all entities that aren't groups
                      next unless e.is_a? Sketchup;;Group
                      # Now we process the groups
                            xc= boundbox.center.x # ??? error
                    xe=xc
                    ye=yc
                    ze=zc
                    if xc<xp
                    xe =xc - 100
                      if xc>xp
                    xe =xc +100
                    if yc<yp
                    ye =yc - 100
                      if yc>yp
                    ye =yc +100
                    if zc<zp
                    ze =zc - 100
                      if zc>zp
                    ze =zc +100
                      point = Geom;;Point3d.new xe,ye,ze
                      t = Geom;;Transformation.new point
                      # Apply the transformation
                      e.transform!(t)
                      That's because of center = boundbox.center <- you haven't referenced boundbox yet.
                      change to
                      center = e.bounds.center
                         xc= center.x
                         yc= center.y
                         zc= center.z
                        Thx! โ˜€
                        More easy with that ๐Ÿ˜„ Works like a charm ๐Ÿ˜Ž
                        I can now test some natures of explodes ๐Ÿ’š
                          Funny thing ๐Ÿ˜„
                            Looking good Pilou!
                            Instant assembly drawings! ๐Ÿ˜„ This should come in handy.
                              Instant assembly
                              Alas for the inverse, that must be more tricky! ๐Ÿ˜•
                              Better is use the Undo ๐Ÿ’š
                                hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
                                though, that will fail if the user moves anything...
                                Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
                                • Chris FullmerC
                                  Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
                                  I wrote that crazy scrambler script a while ago that does this and it worked very well.
                                    In theory that must be more easy ๐Ÿ˜‰
                                    Just select that you want and apply a "negative" translation : a deflation ๐Ÿ˜‰
                                    Maybe my next ๐Ÿ˜„
                                    And the above is not yet perfect! The Pivot Point seems not have the wished result wanted ๐Ÿ˜’
                                    be continued...
                                    Ps When Groups or Components are nested how to process automatically?
                                    A plug for make each components individual is maybe existing?
                                    Edit
                                    one exist for group by TIG Explode2groups
                                    miss now somethings transform Transform2goups or Explode2Components ๐Ÿ˜„
                                      @Chris Any chance to see it somewhere? ๐Ÿ˜„
                                      PS
                                      Edit
                                      miss now somethings for components Transform2goups or Explode2Components
                                      • Chris FullmerC
                                        take the componentInstance, add it to a group, then explode the component instance.
                                        And I posted my scrambler script here. I'll see if I can find the thread.
                                          @Chris thx for the Info โ˜€
                                          Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual)
                                          (last icon)
                                            Some tests ๐Ÿ’š Put the code inside the WebConsole by Jim Foltz
                                            Press "Eval" button and have fun ๐Ÿ˜„
                                            Veyron model is from 3Dwarehouse!
                                            xp=100  # Pivot Point (as you want)
                                            yp=100
                                            zp=100
                                            q=50 # Measure of translation (as you want)
                                              # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                                              next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                                             center = e.bounds.center #Center Point of the grouped object
                                               xc= center.x
                                               yc= center.y
                                               zc= center.z
                                            xe=xc #End Point of the grouped object
                                            ye=yc
                                            ze=zc
                                            if xc<xp
                                             xe =xc - q
                                            if xc>xp
                                             xe =xc + q
                                            if yc<yp
                                             ye =yc - q
                                            if yc>yp
                                             ye =yc + q
                                            if zc<zp
                                             ze =zc - q
                                            if zc>zp
                                             ze =zc + q
                                              e.transform!(t)
                                            • 3 / 3
