    Move groups with different measures?
    55 Posts 4 Posters 34.8k Views 4 Watching
      Looking good Pilou!
      Instant assembly drawings! πŸ˜„ This should come in handy.
        Instant assembly
        Alas for the inverse, that must be more tricky! πŸ˜•
        Better is use the Undo πŸ’š
          hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
          though, that will fail if the user moves anything...
          Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
          • Chris FullmerC
            Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
            I wrote that crazy scrambler script a while ago that does this and it worked very well.
              In theory that must be more easy πŸ˜‰
              Just select that you want and apply a "negative" translation : a deflation πŸ˜‰
              Maybe my next πŸ˜„
              And the above is not yet perfect! The Pivot Point seems not have the wished result wanted πŸ˜’
              be continued...
              Ps When Groups or Components are nested how to process automatically?
              A plug for make each components individual is maybe existing?
              Edit
              one exist for group by TIG Explode2groups
              miss now somethings transform Transform2goups or Explode2Components πŸ˜„
                @Chris Any chance to see it somewhere? πŸ˜„
                PS
                Edit
                miss now somethings for components Transform2goups or Explode2Components
                • Chris FullmerC
                  take the componentInstance, add it to a group, then explode the component instance.
                  And I posted my scrambler script here. I'll see if I can find the thread.
                    @Chris thx for the Info β˜€
                    Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual)
                    (last icon)
                      Some tests πŸ’š Put the code inside the WebConsole by Jim Foltz
                      Press "Eval" button and have fun πŸ˜„
                      Veyron model is from 3Dwarehouse!
                      model = Sketchup.active_model
                      entities = model.entities
                      selection = model.selection
                      xp=100  # Pivot Point (as you want)
                      yp=100
                      zp=100
                      q=50 # Measure of translation (as you want)
                      selection.each do |e| # update!
                        # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                        next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                       center = e.bounds.center #Center Point of the grouped object
                         xc= center.x
                         yc= center.y
                         zc= center.z
                      xe=xc #End Point of the grouped object
                      ye=yc
                      ze=zc
                      if xc<xp
                       xe =xc - q
                      if xc>xp
                       xe =xc + q
                      if yc<yp
                       ye =yc - q
                      if yc>yp
                       ye =yc + q
                      if zc<zp
                       ze =zc - q
                      if zc>zp
                       ze =zc + q
                        point = Geom;;Point3d.new xe,ye,ze
                        t = Geom;;Transformation.new point
                        # Apply the transformation
                        e.transform!(t)
                        Yep!!! THX! Miracle that is working! 😍
                        Sure I should read the Api document before 😳 😳 😳 But I had risked the trick πŸ’š
                        So my second script was a new speedy success and a big lesson πŸ˜„
                        groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::ComponentInstance)}
                        groups.each{|ComponentInstance|zeds.push([ComponentInstance.bounds.min.z, index])
                        Copy my code follow in the Web console from Jim Foltz ❗ ❗ ❗
                        (if you have components use the file linked )
                            model.start_operation("Move in Z")
                            zeds=[]
                            index=0
                            sorted_groups=[]
                            groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                            groups.each{|group|zeds.push([group.bounds.min.z, index])
                               index+=1
                            zeds.sort!
                            zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                            ### sorted_groups is now groups sorted by z
                            z = 0.0
                            sorted_groups.each do |e| # update!
                              # Now we process the groups
                              t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                              e.transform!(t)
                              z = z + 100.cm
                          model.commit_operation
                          return nil
                        Some help for fun variations πŸ˜„
                        http://forums.polyloop.net/picture.php?albumid=23&pictureid=421
                        Undrop_component.zip
                        • 3 / 3
