    Complex curves (3D)
    12 Posts 4 Posters 1.3k Views 4 Watching
    • S
      SFX Group
      Ok, this is doing my nut in....
      Ive grasped SU pretty well.... See enclosed file, then see enclosed pic...
      However how on earth will i get that "visor" designed, bugs me SU doesnt have Beziers (i like those, they work well for this kinda job).
      So how am i going to do it?
      The "+" are fairly accurate for that i need in SU drawing (at least for what i need anyway), so how would i do this?
      Many Thanks
      Ashley
      Real pic
      SU version
      Many Thanks
      Ashley
      Β© Copyright 2014 - http://www.ashleygriffin.co.uk
      • massimoM
        massimo Moderator
        Thake a look at this.
        http://forums.sketchucation.com/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier+fredo
        • S
          SFX Group
          You da man 😍
          Many Thanks
          Ashley
          • S
            SFX Group
            Next part of the problem, how to extrude that (now very nice curve) to something 3D..
            New SKP file enclosed.
            Many Thanks
            SU file
            Many Thanks
            Ashley
            • massimoM
              massimo Moderator
              I don't have SU7 so i cannot open your file. But you can look at this.
              http://forums.sketchucation.com/viewtopic.php?f=153&t=1512
              There is a tool called "extrude lines tool" in the pack.
              • Jean LemireJ
                Jean Lemire
                Hi Ashley, hi folks.
                See this SU file for ideas.
                Dashboard.skp
                • S
                  SFX Group
                  WOw, that was fast.....
                  Interesting you say the orginal line isnt flat, i used the Bezier tool on one plane.... How did you project the line on to the rectangle, i like this idea, would solve alot of problems when they come up?
                  Also how did you "offset" the edge to make it thick, i have just tried in that file and it complains about it not being a face or other errors.....???
                  Never thought of intersecting another angle rectangle and deleting stuff, good idea, i can do this with a slighty rounded surface as well (as the orginal dash is).
                  Many Thanks
                  Many Thanks
                  Ashley
                  • S
                    SFX Group
                    I cant get scene 8 to turn in to scene 9 with the offset tool, it wont let me do it....
                    I cant get anything to turn in to scene 8, how do you "smooth" that out?
                    I assume your not using the basic tools in SU?
                    Many Thanks
                    Ashley
                    Many Thanks
                    Ashley
                      I believe that Jean can use the Joint Push Pull by Fredo6 πŸ˜‰
                      You have the result in one click β˜€
                      • S
                        SFX Group
                        Thanks, found it, that tool is just voodoo (after i worked out to NOT delete faces once its pulled it) 😍
                        Many Thanks
                        Ashley
                        • Jean LemireJ
                          Jean Lemire
                          Hi folks.
                          A - PROJECTION
                          To project the curve to the horizontal plane, I used an old trick I learned in the old @last forum (I was probably using SU 3 at this time). To do that, you follow this procedure:
                          1 - Choose the Line Tool.
                          2 - Hover the cursor over the plane on which you want to project untill you get a pop-up stating "On Face".
                          3 - Press and hold the SHIFT key to lock this inference.
                          4 - Place the cursor on the first endpoint on the curve untill you get a pop-up message stating "Endpoint".
                          5 - Begin the line and draw it using the next endpoint as a inference to end it. Do not let go of the SHIFT key during all these operations.
                          6 - Continue from endpoint to endpoint to draw as many line as you need.
                          7 - When you have drawn the last line, let go of the SHIFT key.
                          B - OFFSET
                          I did not use any plugins.
                          However, some pluggins can save a lot of steps.
                          Dashboard 2.skp
                            yes possible too πŸ˜‰
