    Complex curves (3D)
    12 Posts 4 Posters 1.3k Views 4 Watching
      SFX Group
      @massimo said:
      Thake a look at this.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier+fredo
      You da man 😍
      Many Thanks
      Ashley
      Β© Copyright 2014 - http://www.ashleygriffin.co.uk
        SFX Group
        Next part of the problem, how to extrude that (now very nice curve) to something 3D..
        New SKP file enclosed.
        Many Thanks
        SU file
        Many Thanks
        Ashley
        • massimoM
          massimo Moderator
          I don't have SU7 so i cannot open your file. But you can look at this.
          http://forums.sketchucation.com/viewtopic.php?f=153&t=1512
          There is a tool called "extrude lines tool" in the pack.
          • Jean LemireJ
            Jean Lemire
            Hi Ashley, hi folks.
            See this SU file for ideas.
            Dashboard.skp
              SFX Group
              WOw, that was fast.....
              Interesting you say the orginal line isnt flat, i used the Bezier tool on one plane.... How did you project the line on to the rectangle, i like this idea, would solve alot of problems when they come up?
              Also how did you "offset" the edge to make it thick, i have just tried in that file and it complains about it not being a face or other errors.....???
              Never thought of intersecting another angle rectangle and deleting stuff, good idea, i can do this with a slighty rounded surface as well (as the orginal dash is).
              Many Thanks
              Many Thanks
              Ashley
                SFX Group
                I cant get scene 8 to turn in to scene 9 with the offset tool, it wont let me do it....
                I cant get anything to turn in to scene 8, how do you "smooth" that out?
                I assume your not using the basic tools in SU?
                Many Thanks
                Ashley
                Many Thanks
                Ashley
                  I believe that Jean can use the Joint Push Pull by Fredo6 πŸ˜‰
                  You have the result in one click β˜€
                    SFX Group
                    Thanks, found it, that tool is just voodoo (after i worked out to NOT delete faces once its pulled it) 😍
                    Many Thanks
                    Ashley
                    • Jean LemireJ
                      Jean Lemire
                      Hi folks.
                      A - PROJECTION
                      To project the curve to the horizontal plane, I used an old trick I learned in the old @last forum (I was probably using SU 3 at this time). To do that, you follow this procedure:
                      1 - Choose the Line Tool.
                      2 - Hover the cursor over the plane on which you want to project untill you get a pop-up stating "On Face".
                      3 - Press and hold the SHIFT key to lock this inference.
                      4 - Place the cursor on the first endpoint on the curve untill you get a pop-up message stating "Endpoint".
                      5 - Begin the line and draw it using the next endpoint as a inference to end it. Do not let go of the SHIFT key during all these operations.
                      6 - Continue from endpoint to endpoint to draw as many line as you need.
                      7 - When you have drawn the last line, let go of the SHIFT key.
                      B - OFFSET
                      I did not use any plugins.
                      However, some pluggins can save a lot of steps.
                      Dashboard 2.skp
                        yes possible too πŸ˜‰
