    Complex curves (3D)
    12 Posts 4 Posters 1.1k Views 4 Watching
      SFX Group
      Ok, this is doing my nut in....
      Ive grasped SU pretty well.... See enclosed file, then see enclosed pic...
      However how on earth will i get that "visor" designed, bugs me SU doesnt have Beziers (i like those, they work well for this kinda job).
      So how am i going to do it?
      The "+" are fairly accurate for that i need in SU drawing (at least for what i need anyway), so how would i do this?
      Many Thanks
      Ashley
      Real pic
      SU version
      Many Thanks
      Ashley
      Β© Copyright 2014 - http://www.ashleygriffin.co.uk
      • massimoM Offline
        massimo Moderator
        Thake a look at this.
        http://forums.sketchucation.com/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier+fredo
          SFX Group
          You da man 😍
          Many Thanks
          Ashley
            SFX Group
            Next part of the problem, how to extrude that (now very nice curve) to something 3D..
            New SKP file enclosed.
            Many Thanks
            SU file
            Many Thanks
            Ashley
            • massimoM Offline
              massimo Moderator
              I don't have SU7 so i cannot open your file. But you can look at this.
              http://forums.sketchucation.com/viewtopic.php?f=153&t=1512
              There is a tool called "extrude lines tool" in the pack.
              • Jean LemireJ Offline
                Jean Lemire
                Hi Ashley, hi folks.
                See this SU file for ideas.
                Dashboard.skp
                  SFX Group
                  WOw, that was fast.....
                  Interesting you say the orginal line isnt flat, i used the Bezier tool on one plane.... How did you project the line on to the rectangle, i like this idea, would solve alot of problems when they come up?
                  Also how did you "offset" the edge to make it thick, i have just tried in that file and it complains about it not being a face or other errors.....???
                  Never thought of intersecting another angle rectangle and deleting stuff, good idea, i can do this with a slighty rounded surface as well (as the orginal dash is).
                  Many Thanks
                  Many Thanks
                  Ashley
                    SFX Group
                    I cant get scene 8 to turn in to scene 9 with the offset tool, it wont let me do it....
                    I cant get anything to turn in to scene 8, how do you "smooth" that out?
                    I assume your not using the basic tools in SU?
                    Many Thanks
                    Ashley
                    Many Thanks
                    Ashley
                      I believe that Jean can use the Joint Push Pull by Fredo6 πŸ˜‰
                      You have the result in one click β˜€
                        SFX Group
                        Thanks, found it, that tool is just voodoo (after i worked out to NOT delete faces once its pulled it) 😍
                        Many Thanks
                        Ashley
                          Jean Lemire
                          Hi folks.
                          A - PROJECTION
                          To project the curve to the horizontal plane, I used an old trick I learned in the old @last forum (I was probably using SU 3 at this time). To do that, you follow this procedure:
                          1 - Choose the Line Tool.
                          2 - Hover the cursor over the plane on which you want to project untill you get a pop-up stating "On Face".
                          3 - Press and hold the SHIFT key to lock this inference.
                          4 - Place the cursor on the first endpoint on the curve untill you get a pop-up message stating "Endpoint".
                          5 - Begin the line and draw it using the next endpoint as a inference to end it. Do not let go of the SHIFT key during all these operations.
                          6 - Continue from endpoint to endpoint to draw as many line as you need.
                          7 - When you have drawn the last line, let go of the SHIFT key.
                          B - OFFSET
                          I did not use any plugins.
                          However, some pluggins can save a lot of steps.
                          Dashboard 2.skp
                            yes possible too πŸ˜‰
