    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 44.0k Views 13 Watching
      #SelectionHideShow.rb adds a context-menu sub-menu with various Selection, Hide and UnHide tools, such as 'Invert Selection', 'Hide/UnHide Selection', 'UnHide All Active' etc...#SelectionHideShow.rbPayPalButton
      Edit:
      v1.1 Now tests with ".is_a?" to speed-up and avoids testing already unique groups[after AlexM's advice].
        Very practical! 😎
          Mr S
          Great!
          I asked for this a while ago.
          I suggested it was something that should be a standard feature in SketchUp
          Now it is. Thanks for another great contribution.
          Regards
          Mr S
          • boofredlayB Offline
            boofredlay
            Thanks TIG. However I expected to see Reverse Faces in there too.
            • erikBE Offline
              erikB
              Thanks TIG, and I second the request made by Boofredlay.
              erikB
                Reverse and Orient faces is already built-in on the context-menu - near the top [as are some other 'select tools']... adding them would only duplicate stuff...
                  AlexMozg
                  ❓ Why constantly to use the method of group_miner, when in him practically is not there a necessity?
                  ❓ Why to apply properties to entity, when are new properties of entity equal to the applied properties?
                  These questions are linked at a speed of implementation of script on the large scenes.
                  ❗ Example of considerable increase of speed of implementation of script:
                  class Sketchup;;Group
                      def definition
                          self.entities.parent
                  def SelectionTool;;group_miner(ents)
                      ents.each do |e|
                          if e.is_a? Sketchup;;Group
                              e.make_unique if e.definition.instances.length > 1
                              SelectionTool;;group_miner(e.entities)
                  ❗ At the use of method of typename speed of implementation of script goes down in once or twice!
                  It would be desirable to correct these shortages...
                  • Chris FullmerC Offline
                    Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
                    I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
                    Chris
                    All my Plugins I've written
                      AlexMozg
                      Chris
                      Easily to check...
                      The more elements in the model - the better results script.
                      SpeedTest
                      is_a? - 0.36c
                      kind_of? - 0.39c
                      class - 0.422c
                      typename - 1.313c
                      Model Statistics:
                      edges = 48981
                      faces = 8009
                      groups = 729
                      components = 365
                      construction_lines = 1
                      construction_points = 4
                      images = 3
                      section_planes = 4
                      texts = 4
                      others = 2
                      Not plugin!
                        That's some interesting numbers. I've always used k ind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
                        Thanks for posting this test.
                          Maybe we could add this info to a new stickcy where we collect such useful tips and info?
                            Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
                            I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... πŸ€“
                            I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😒
                            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
                              AlexMozg
                              @tig said:
                              ...I didn't realise it was so much slower to use typename=="". 😳
                              For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
                              My model statistics:
                              Model 68.4 Mb:
                              Edges 485016
                              Faces 128906
                              Component Instances 6055
                              Groups 3078
                              Section Planes 4
                              P.S.
                              It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
                              πŸ˜’
                                bianhai
                                Very good 😎 !
                                  Chris
                                  Easily to check...
                                  SpeedTest
                                  is_a? - 0.36c
                                  kind_of? - 0.39c
                                  class - 0.422c
                                  typename - 1.313c
                                  Model Statistics:
                                  edges = 48981
                                  faces = 8009
                                  groups = 729
                                  components = 365
                                  images = 3
                                  section_planes = 4
                                  texts = 4
                                  others = 2
                                  Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
                                  http://www.ruby-doc.org/core/classes/Object.html#M000370
                                    I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
                                    AT - SpeedTest:
                                    is_a? - 0.89c
                                    kind_of? - 0.782c
                                    class - 0.875c
                                    typename - 2.297c
                                    Model Statistics:
                                    edges = 159630
                                    faces = 61300
                                    groups = 0
                                    components = 1000
                                    construction_lines = 0
                                    construction_points = 0
                                    images = 0
                                    section_planes = 0
                                    texts = 0
                                    others = 0
                                      Much larger test. (did have a few programs open while I did the tests.)
                                      AT - SpeedTest:
                                      is_a? - 16.297c
                                      kind_of? - 16.141c
                                      class - 18.703c
                                      typename - 88.703c
                                      Model Statistics:
                                      edges = 8396595
                                      faces = 1026520
                                      groups = 52643
                                      components = 526428
                                      construction_lines = 2
                                      images = 0
                                      section_planes = 0
                                      texts = 0
                                      others = 0
                                      • 3 Offline
                                        3dsmax9
                                        a tool bar will be very great with this script
                                        • irwanwrI Offline
                                          irwanwr
                                          i think i need this plugin
                                          thank you in advance, sir.
                                          • I Offline
                                            Ivancho
                                            [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                                            • 1 / 2
