    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 48.1k Views 13 Watching
    • H
      hygicell
      I have lost a component somewhere in my drawing
      to find it, I pasted a second one in a visible place
      when I select this, the entity info clearly says Component (2 in model)
      with the components window context menu, I selected all components
      I thought then, if I could hide the rest of the model, I would easily spot where the original one is
      but view/hide rest of model doesn't work unless you are inside the component,
      which means you can select only one of both, and the other one is deselected
      please help
      Frank
      • TIGT
        View > Hidden Geometry ON will show all hidden objects.
        If it's on a Layer that is OFF you won't see it though...
        The Outliner will also show all instances that are on ON Layers...
        You can select them in the Outliner and they select in the model.
        • 2 / 2
