    Edge bevel question
    18 Posts 8 Posters 2.7k Views 8 Watching
    • CarrozzaC
      Carrozza
      I'm trying to bevel an inner edge of two intersected objects; I tried using FollowMe and Bezier RoundEdge but can't get it.
      Any suggestion?
      http://img24.imageshack.us/img24/6966/round.gif
      • jeff hammondJ
        jeff hammond
        that's pretty tough to do in sketchup.. how accurate does it need to be and if accuracy is important, do you want the same radius all the way around with a fluctuating offset or the same amount of offset with a fluctuating radius?
        dotdotdot
        • L
          lucifer1101
          try using intersect with model and then delete the unwanted geometry
          edit: nvm misread the question
          Some of my 3d
          • CarrozzaC
            Carrozza
            Well, I'm for a simple bevel, like the one at the top of the nested shape.
            By the way after some tests I believe is not possible to achieve it in SketchUp.
            It looks like the problem is the base of the cylinder is curved in two ways: as a circle and as laying over the underlying curved surface.
            • A
              Aerilius
              See the attachment. It's not a perfect way, but you can experiment with it.
              bevel_on_concave_face.skp
              • TIGT
                Here's a manual method. It makes a complex angled bevel around the cylinder.ComplexBevel.png
                ComplexBevel.skp
                • thomthomT
                  I wonder, could Chris' Bend plugin be used here?
                  • CarrozzaC
                    Carrozza
                    Thanks for your help, guys!
                    I like TIG solution best, but man! That's a crazy workflow to bevel an edge!
                    OK, we'll survive, gonna play around that... πŸ˜„
                    • jeff hammondJ
                      jeff hammond
                      the problem is that the angle between the tube and it's mating surface changes..(in the original post's picture, the area near your arrow is an obtuse angle and changes to 90deg at the sides).. that drawing also shows that you're not wanting a simple bevel rather a radius..
                      TIG's drawing makes more sense of what i was getting at in my first post in that the amount of offset grows as it nears the top/bottom of the joint.. you could also do it where that amount stays the same and the angle changes..
                      i put in a feature request for the subdivide&smooth plugin that would handle this nicely.
                      http://www.sketchucation.com/forums/scf/viewtopic.php?p=149839#p149839
                      dotdotdot
                      • TIGT
                        In my version the offset stays the same and the bevel's angle changes the further down the curving block it is. Of course you could try having a constant angle bevel and then the offset would be variable... but against a curved surface that falls away there's a chance that it's never meet it...
                        You have to think how this might be done in 'real life' - after all, we are only modelling it as an approximation - chances are it would be a bit of both - on 'professional bodge'...
                        • TIGT
                          Pilou - great ideas... πŸ€“
                            I have forgotten to say : Mirror 3 points by TIG πŸ˜‰
                              Another solution πŸ˜‰
                              So it's a variable fillet πŸ˜‰ (the best fillet but depending of what is needing πŸ’š
                              Mirror by TIG
                              • TIGT
                                I was praising your thinking, I wasn't criticising you not mentioning my Mirror-tool !
                                [J'ai Γ©tΓ© en louant votre rΓ©flexion, je ne chante pas la critique de ne pas mentionner mon outil 'Mirror'!] πŸ˜„
                                  Of course yes, but the funny thing is that I did'nt remember the author of the Mirror plug, so when I saw that was the "Tiger", I could'nt resist πŸ˜„
                                  A cool thing will be a "sweep 2 rails" in SU so here Arc is the profil, Rail 1 = "circle 1" (curve 3D) , rail 2 = circle 2
                                  So just draw one arc, one circle on surface and 2 clicks πŸ˜’
                                    .it is just a follow-me with the bevel profile and then intersect
                                    That will be wonderful but you can't πŸ˜‰
                                    At some place upper profil can't "past" to the cylinder!
                                    Result gives some crack fissures!
                                    • jeff hammondJ
                                      jeff hammond
                                      right, with a simple angled bevel, you could do it as modelhead is saying.. the 'bevel' shown in Carrozza's original picture will cause the problem that frenchy is showing.. the joint's intersecting angle doesn't remain consistent so something has to give when you try putting another radius in there. blending 3 curves together like that is always going to pose a problem because there are so many variables at play.
                                      dotdotdot
                                      • CarrozzaC
                                        Carrozza
                                        Yes it's a tricky edge to deal with.
                                        To date Pilou's solution is the most clean and customizable.
