    Displacement Shapes
    renderpluginsextensions
    29 Posts 12 Posters 5.5k Views 12 Watching
      Ok. I'm curious. What kind of shapes can you make out of a single square with an displacement map using your render engine of choice?
      Sketchup View
      V-Ray SR1.5 Render
      Test Scene - 1x1m square
      8bit Version of the Displacement Map
(The one I used was 32bit)
        I'm thinking a larger scene with different displacements will be interesting. Alien-ish.
        • soloS Offline
          solo
          Slow day in the office? πŸ˜†
          Lookibg cool by the way.
          http://www.solos-art.com
            I wrote the UV tool during slow day at the office. πŸ˜‰
            This is me going through The Complete V-Ray Guide. Some of the examples had some extreme displacement, which gave me an idea I wanted to try out.
              Click Draw
              Looks like something Madonna might wear in concert 🀣
              Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                The big boobie you mean?
                πŸ˜„
                  The Fallen Madonna with the big boobies?
                  • EarthMoverE Offline
                    EarthMover
                    Looks cool Thomas. I started going through the Complete guide myself. What a book! Sometime in 2011 I'll let you know how it is when I finish it.
                    Content Creator at Skapeup
                      I hadn't expected it to be that big. Somehow, the word "Guide" gave me a metnal image of a pocket-sized book. This thing is a behemoth! Hopefully this'll teach me a thing or two about V-Ray. ...but where to begin?
                      • soloS Offline
                        solo
                        I seem to have a little glitch with my vray, I have recently installed vray on my new machine and everything works great but it does not render displacement, it shows it in material preview window but not in render.
                        I checked the same model on an older machine and it renders the displacement fine, is there someplace I need to check to enable displacement?
                        [edit] Figured it out, I'm having a blonde moment.
                          Care to share what you'd done in your blonde moment?
                          • soloS Offline
                            solo
                            The model size on the new machine was too big so the dispacement value over the texture was reduced to a point that it was not noticable.
                            • FrederikF Offline
                              Frederik
                              Ouch... Have to admit that it also have happened for me... 😳
                              Recently it happened when I tried using your Vray Grass displace model... πŸ‘Ώ πŸ˜†
                              Didn't realize it was like 30cm grass... πŸ˜†
                              Aaahhh well... Good to know that I'm not the only occasional "blonde" around... πŸ˜†
                              Cheers
                              Kim Frederik
                              • soloS Offline
                                solo
                                LOL, I have many blonde moments these days, must be age.
                                Thomthom, I used your displacement map from your first post and tried it with Vue:
                                http://img12.imageshack.us/img12/9549/ttdisplacement.jpg
                                I then exported the displaced mesh and opened it in SU.
                                http://img12.imageshack.us/img12/1562/displacementmesh.jpg
                                  The one I used isn't the one I posted here. I used an 32bit image, as 8bit images will have a non-linear gamma correction applied it.
                                  How did you create the mesh? Terrain generated from bitmap?
                                  • soloS Offline
                                    solo
                                    Yes.
                                      BTM
                                      I bet it would be possible to make a whole mountain scene with a displacement map πŸ’š
                                      • soloS Offline
                                        solo
                                        Another quick test.
                                        Image made in paintshop:
                                        http://img7.imageshack.us/img7/7862/testdisp.jpg
                                        Then the displacement/terrain from image:
                                        http://img7.imageshack.us/img7/5422/testdisplacement.jpg
                                        And lastly the mesh from terraim/displacement opened in SU.
                                        http://img7.imageshack.us/img7/3478/testdisplacementmesh.jpg
                                          More 'boobies'. Tried out Two-Sided material. Though, I had expected it to be more translucent. Need to revisit this one. Other tests on plain geometry gave the results I expected, this one didn't. Wonder if it's due to the displacement.
                                          • soloS Offline
                                            solo
                                            I used your map again this time with Vray, and an American flag as a diffuse map.
                                            It UV mapped it perfectly....hmmm.
                                            http://img20.imageshack.us/img20/9247/usflagdisp.png
                                            • 1 / 2
